hello all. i recently purchased a used 22 ton log splitter with a haldex 11 gpm pump. after sitting in the garage i noticed a small puddle starting under the pump area. upon further investigation i found that the intake tube is leaking! the intake is a barb-type nipple that sticks out of the pump in which you slide on the tube and hose clamp. it is leaking where this nipple meets the pump housing. i thought it may be threaded in and i could just tighten it, but i was wrong. it spins freely in the housing. how do i fix this? please don't tell me i need to buy a new pump. thanks in advance...
