Log Splitter problem
/ Log Splitter problem
So far the only smart thing I have done is ask for help on TBN. I picked up my splitter today and ordered a new pump from northern hydraulics. They charged me $50 for teaching them how to check the pump. The pump should be here in a couple days. I will start taking things apart tomorrow. I have decided to drain the tank and give the new pump some fresh hydraulic oil. What should I use to flush the tank out with? Can I use diesel fuel? I am pretty sure I will run into some differences between the two pumps. I'll keep you all updated on my progress. Thanks!
CJ
/ Log Splitter problem #32
Glad to hear CJ.....Kero works better for cleaning/rinsing but diesel will work too.....get a clean rag in there if you can
/ Log Splitter problem #33
Given what I've read I would be adjusting the detent pressure on the valve down a tad and continuing to use it. Some valves don't have adjustable detent pressure but others do.
If the splitter splits normally otherwise I wouldn't worry about a few psi less overall.
Just adjust the detent pressure so it kicks off at a lower pressure.
I'd only swap out the pump if the cylinder is slower than usual or if it can't split logs it used to be able to.
I finally installed the new pump I bought from northern hydraulics. I had to buy a new coupling half because the new pump shaft diameter was 1/2" and the old pump was 7/16".
Anyway, it only took a few minutes to mount the new pump and it runs great. The best part is I saved several hundred dollars by doing it myself and not buying the pump from the dealer. I only split a couple pieces of wood but I plan on running it for several hours tomorrow I hope I'm not celebrating prematurely. I will know more about the performance after tomorrow. Again I want to thank everyone on the site for all the help and encouragement. TBN has been one of my favorite sites for years. I think it is great the way people help each other on this site. Thanks!
CJ
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
Giyi Mini Ex Attachment Set (A60463)
Giyi Mini Ex...
2016 FORD F-350 XL SUPER DUTY EXT CAB TRUCK (A59823)
2016 FORD F-350 XL...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
2021 Kubota B2601 (A60462)
2021 Kubota B2601...
2011 BIG TEX 40 GOOSENECK (A60736)
2011 BIG TEX 40...
