log splitter parts
/ log splitter parts #1
goaliedad
NORTHWEST MICHIGAN
KUBOTA L175
OK troops- my SIL was splitting wood today with his fathers old MTD splitter- the wedge is fixed to the beam and there is a plate on the end of the cylinder. It seems as if this plate has been welded several times over the years and met it's match against a forked piece of elm. Any ideas where to get a replacement- sort of having one made up at a local shop? I don't have a model number, which I know would be helpful. Thanks in advance
/ log splitter parts #2
Did the weld break where welded to the cylinder push rod?
A picture would help.
My splitter has a fixed wedge, and the cylinder end just fits into a pipe-like socket on the bush plate. A pin holds it in the socket.
Maybe it's something you can fashion.
I haven't seen it- just talked to sil- I think we will have to have one fabricated- was hoping that there was a source for generic oarts- i guess it's off the local fixit guy.
/ log splitter parts #5
A picture will tell a thousand words and you will get some ideas on how to permantely fix it from breaking again.
2009 Mack GU813 Roll off Truck, VIN # 1M2AX13C59M007359 (A61165)
2009 Mack GU813...
2001 JOHN DEERE 770CH MOTORGRADER (A62129)
2001 JOHN DEERE...
UNUSED WOLVERINE SB66-66" ROCK BKT (A62131)
UNUSED WOLVERINE...
(2) 1500 Gallon Tanks w/ Pump (A64047)
(2) 1500 Gallon...
UNUSED KJ K1522 PORTABLE RESTROOM (A62131)
UNUSED KJ K1522...
2013 John Deere 1790 Planter (A63109)
2013 John Deere...
