Log splitter hydraulic problems
   / Log splitter hydraulic problems #21
Does the cylinder extend at full speed or how many seconds does it take to extend? What is the bore and stroke of the cylinder? With time and size flow can be calculated.
Possible the hi - lo sequence valve is stuck from sitting for nine years. Since this valve recirculates the oil from pump outlet to inlet it might cause aeration. Cylinder speed above should answer this question
   / Log splitter hydraulic problems #22
Have you checked the pump to engine coupling? Maybe the keyway fell out.
It takes about 90 seconds to extend the cylinder and about the same to retract, slow and jerky motion in both directions, i also did check the the lovejoy key was inplace and setscrews were tight
   / Log splitter hydraulic problems #24
I’d guess the pump has about got to be bad.
   / Log splitter hydraulic problems #25
Is there a filter that might be plugged creating more suction and an air leak?
Are these pumps able to be rebuilt, if not what is a good pump to replace it with
   / Log splitter hydraulic problems #28
I’m sure it’s possible, but log splitter pumps are cheap. The labor would probably cost more than another pump. Do you want quality or cheap? The cheapest pumps I’ve found are sold on amazon. I don’t remember the brand but the end is blue and the other end is aluminum.
Im all about being cheap, but I also know when not to be. This is the time I would rather spend good money for better quality. What is a good brand name?
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
2006 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51243)
2006 FORD F750 XLT...
1042 (A50459)
1042 (A50459)
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
Toro Sprayer Cart (A50324)
Toro Sprayer Cart...
