Log Splitter - Hydraulic Filter re-placment
   / Log Splitter - Hydraulic Filter re-placment #1
slimpickins28
Somerset, Ky
Kubota B7100 HST, Belarus 572, Ford 3000
Hey guys...browsed this site many times for info...now I need some specific information!
I haven't started it yet, as the guy said the engine's carb is all screwed up...I have another engine I was just going to throw on it off a snow blower (with electric start!! =) )
I bought a used homemade log splitter. This uses a big cylinder off some implement, the plate is covered, so I'm not sure of the size. However my question is about the hydraulic filter. The pump is a 2 stage 11gpm pump. The filter that was put on it was is on the suction side of the reservoir between that and the pump. The problem I'm seeing is that according to the website on about the filter, its rated at 5gpm on the suction side, and 25gpm on the filter side.
With the above info, does that mean that the filter is really limiting the pump??? While I was changing the engine, I can "fix this" however..not sure if I was correct in my thinking or am way off
thanks ahead
   / Log Splitter - Hydraulic Filter re-placment #2
A suction filter on that kind of pump is not a good idea.
Get the proper return filter.
Should I try and find a filter screen or something to put on the suction? or just change the hoses around and "let her rip" ?!
   / Log Splitter - Hydraulic Filter re-placment #4
Most people only have a return filter.
Match the GPM the filter will handle with the pumps capacity and observe the micron rating, probably around 10 to 15 microns.
Thanks man!! I'll just swap its location...I think that will help out a lot.
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
2022 Wacker Neuson SM100 Mini Skid Steer (A52128)
2022 Wacker Neuson...
International 720 6-Bottom Plow (A52128)
International 720...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
SET OF MILWAUKEE TOOLS (A51243)
SET OF MILWAUKEE...
