log splitter help
/ log splitter help #1
IowaKubota51
PLeasant Hill, Iowa
2011 Kubota BX2660
I have a log splitter and I'm having issues with its splitting, in the dead of winter I cannot split a 14" dia. oak log. So here is what I have; 8hp engine coupled to a 13.6 gpm 2-stage transmission pump, from pump to valve in is 3/4' hydraulic line, from valve to 4" bore x 2" rod x 28" travel cylinder is 1/2" on both ends and valve out to tank is 3/4".
Maybe my hopes are too high for my system but if anyone sees any issues any feedback is much welcome. Thank You. ァZachァ
/ log splitter help #2
It is the diameter of the cyl and the pressure that determines the splitting force, and if everything is working, it should normally split.
If the pump is not working as advertised and the cyl seals are leaking, and the return filter is clogged, you may have problems.
I am assuming you meant two stage pump. Maybe it is not shifting to the high pressure and low GPM's.
37,699 lbs of force is achieved by using a 4 in cyl and 2 in shaft and 3000 psi.
/ log splitter help
Thanks J J I have a pressure gauge on the in side of the valve and it never gets above 1200 psi.
/ log splitter help #4
I have a 22 ton splitter, it seemed like it wasn't running well. It would even die while splitting at times. I changed all the fluids and the filter (briggs oil too). The machine came back to life and all was well again. I was amazed at how that little bit of maintenance made such a difference.
/ log splitter help #6
Since your pressure never get abouve 1200psi, this is where I would start looking for the problem. Possible causes.
1. Relief valve not set high enough. Try adjusting relief and see if your pressure setting goes up. If not, possible causes.
2. Pump bypassing internally, not allowing suffence pressure build up. The fact that it builds up to 1200psi suggests that the pump is indeed shifting from high/flow low pressure to low flow/high pressure since a two stage pump generally makes that shift at 600-900psi. Might want to try capping off a hydraulic line after pressure guage to deadhead fluid flow and see if the pump will actually build more than the 1200psi it is currently showing. If it wont, and adjusting relief doesnt help, then time for a new pump. If you do get a pressure build up. Next step
3. Valve could be bypassing , do same cap and deadhead of hydraulic line after valve and between cylinder. If you get more pressure build up, valve good, if not, replace or rebuild valve.
4. If pump and valve check out, time to take a look at the cylinder. If pressure is good at valve and pump, then it has to be bypassing thru the cylinder. You can fully extend or retrack the cylinder and unhook one hose, activate valve and see if fluid escapes from cylinder. Warning, make sure the hose you unhook is not the one that you activate pressure to, otherwise, big oil spray and mess. If cylinder is fully extended, the hose on the rod end of cylinder would be the one to unhook. If after applying pressure to opposite hose, oil flows out of rod end cylinder port, its a safe bet that the cylinder is bypassing and need rebuilt or replaced. If you get a big gush of oil out of cyl, it could be because you didnt have the cylinder fully extended, but that big gush of oil should stop pretty quick and either not flow at all or very little. If lots of oil keeps coming out, your cylinder is bad.
(12) John Deere 1.5bu. seed boxes for JD 7200 planter, Taylor Ridge, IL (A65640)
(12) John Deere...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
78in. Skid Steer Bucket (A65640)
78in. Skid Steer...
1996 International 4700 (A64127)
1996 International...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
