Log splitter detent
   / Log splitter detent #1
cabin kioti
Bronze Member
Sullivan County Pennsylvania
ck 30 hst
I have a log splitter that i built 6 or 7 years ago. It has a two stage pump and a 5hp B/S engine. The splitter worked fine untill this year when on the return stroke it would not kick into neutral on the return stroke. I replaced the detent assembly and it is still the same. It would stall the motor on the return stroke if I didn't kick it out manually. I just installed a new Prince log splitter valve and it worked fine most of the day and would kick out on the return stroke. All of a sudden on the return stroke no kickout and the engine would stall out. I should say that there is plenty of force to split anything I put on the splitter.I am stumped.I have a filter on the return line.
   / Log splitter detent #2
Put a hyd gage in the system and check the pressure.
That kick out pressure is adjustable, about 1000 to 2000 psi , as is the relief valve.
   / Log splitter detent #3
Sounds like you have some schmutz in the lines somewhere. Mine did this when I first fired it up after sitting for many years. My kick-out linkage was rusty and stuck, the spool was sticky and even after all that was fixed, it still would not kick out. When I removed the lines from the output of the valve, some black mushy pieces came out, I still don't know what they were, but it's been fine since. Even with a filter, some stuff may get hung up in low valleys in the valves.
Paul
2021 Caterpillar 428 4x4 Extendahoe Loader Backhoe (A52377)
2021 Caterpillar...
2013 Ford F-150 Ext. Cab Pickup Truck (A53422)
2013 Ford F-150...
Toro GreensMaster 1600 Walk-Behind Reel Mower (A53421)
Toro GreensMaster...
New Holland TS6.130 4WD Utility Tractor with Slope Mower (A53421)
New Holland...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
