Log splitter build
/ Log splitter build #21
Love it. Really nice work on that. I'm hoping to make one soon. I have a steel beam. I just need to get the other supplies. I'm thinking about putting a four cylinder Mazda truck engine on it. Ideas, Ideas.
Either that or just make one that will adapt to my excavator as I could sit on my excavator and split wood that way. lol
Chad
drs1023 said:
Bobcat Firewood Cutter Attachment - YouTube
Cut and paste this entire link. I could use one of these for about two hours a year. At my age, it would never pay for itself, but this is great.
Hay, I would love to have one! That looks like just about the best firewood processor on the market today! Real quick too! But for me, no more firewood than I cut, I have exactly what I need.
thanks
Well, It was finally time to fire her up. 3 pulls and that new Briggs was running. I only had 1 leak to fix, so we started splitting. My oldest son had the honor to name our new splitter. Bulldog it is. This morning I took bulldog out to the wood pile, fired her up, and just let it run for about 15 minutes, then I got to work. I had 25 rounds to split. Took about 2 hours. I would split a few pieces, and then check over for leaks. As the hydro fluid warmed up, it pushed about 2 quarts out of the breather. I guess that is its "full spot". It took 20 gallons to fill up the tank. It still had some room left, which I thought would have been enough room for expansion. Leaking 2 quarts isn't much of a problem. After that, bulldog was good to go. I left the pressures set at the factory settings for a couple runs. 2300 psi. Design specs are for 3000, but I figured I would put some run time on everything before cranking her up. There was one piece that the wedge berried up in, and it wouldn't split. I just rocked the big round to loosen it up from the wedge, and moved it around a bit. It popped open on the second try. It makes me proud to have built my own splitter, and even happier to see it run. I can claim it was built in America, because it was. With foreign parts!
thanks
FORD 5610 TRACTOR (A64276)
FORD 5610 TRACTOR...
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
213078 (A64276)
213078 (A64276)
2000 Artic Cat ZR600 Limited Edition Snow Mobile (A62613)
2000 Artic Cat...
2012 Chevrolet Silverado 1500 Pickup Truck (A61573)
2012 Chevrolet...
MASSEY FERGUSON 135 TRACTOR (A64276)
MASSEY FERGUSON...
