xring100
- Joined
- Dec 9, 2012
- Messages
- 1,532
- Location
- Livingston County, Michigan
- Tractor
- Kubota M8540, ZD1211 60"
I just purchased a log splitter and my decision came down to primarily the split-fire or the super split. I wound up with the super split but if I didn't need as much speed I think I would have bought the split-fire. Where are you from in MI? I'm fairly close to Clarkston; if you would like to check ours out and/or operate it, you would be more than welcome to come by sometime. Flint New Holland had a split-fire on their showroom floor not too long ago.
Log Splitter, Wood Splitter - Super Split(R)
The super split is an excellent spliter also.
I ordered my splitfire from joe Curtis at flint new holland. I considered ordering a supersplit since I had a speeco kinectic for 6 months before returning it to TSC.
The kinetic was fast but with the small push block you could only half the logs then it took two more splits to 1/4 the log. it took 3 cycles to equal 1 stroke of my 4 way split fire. Each stroke takes between 4.5 and 5.5 seconds for my split fire. Needless to say the split fire works out to be somewhere between 1.75 and 2.5 times faster depending on the wood being split. As long as a I cut to 16" length I can fit two pieces on the spliter so I never have to use a return stroke and split in each direction. If i wanted longer lenght I would get a 28 or 32" model I dont remember all the sizes they build
The other con of the kinetic was that knotty wood had a tendency to ride up the wedge and fly back at me. I wound up with a seriously brushed hand protecting the family jewels. I wore a cup after that day.
Big wood was also pain in the butt. No lift and no option for horizontal spliting made spliting stuff like this a royal pain.
