Log Splitter Add On Idea Help
/ Log Splitter Add On Idea Help #1
GoodGuy
Nova Scotia, Canada
JD 4210 E-Hydro
I have a 3ph Log Splitter and although it has a 5" I-Beam, it doesn't have any way to keep the log from rolling off the beam while I am splitting the piece. I need to fabricate a rack system so when I load the log, it stays centered on the I-Beam. Looking for your suggestions or pictures of what/how your splitter is set up. Also, I would like to fabricate a rack system so that after the piece is split, it doesn't fall to the ground but lays on a rack to help me from having to bend over to pick the pieces off the ground. Your design ideas/fabs (pics) would be appreciated, Thanks, Eric
/ Log Splitter Add On Idea Help #2
Do a Google search for Super Split. I have one of these splitters the table works great on it. Here's a picture of it. I can take some close up shots if you like.
/ Log Splitter Add On Idea Help #3
The firewood forum at
new.arboristsite.com
Has many homebuilt splitters pictured. You would have to do a search to find the threads. Most of them have log lifts and in/out feed tables.
Harry K
/ Log Splitter Add On Idea Help #4
JimR.....
I will take you up on your offer for up close pics of the table & sides around the split wedge. That design from what I can see, seems like what I think I want, so some closeups would be appreciated. Thanks, Eric
/ Log Splitter Add On Idea Help #5
Also, depending on which side your wedge is one will make a huge difference. I have had both and I like the wedge on the opposite end of the hydro. The wood will almost explode off when the wedge is on the hydro side.
/ Log Splitter Add On Idea Help #6
I'll post the photos tomorrow as the splitter is in my barn now. The wedge on this unit is at the table end.
JimR......
Understood & at your convenience....
Thanks, Eric
BTW that looks like a nice splitter & the video shows that it's quick as well.
/ Log Splitter Add On Idea Help #8
GoodGuy, This splitter has a 1.5 second forward stroke and 1 second return. It is faster than anything I have ever seen or used before. I can split wood at least 3-4 times faster than my 3pt mounted hydraulic splitter. The time cycle is 33 seconds on my hydraulic splitter. That makes this unit 12 times faster than my hydraulic splitter. But I am not that fast to keep up with it. A friend of mine has had one of these Super Split's for 15 years. He swears by it and sold me on getting this one. I can split a full 8' pickup load of wood into small pieces in less than 30 minutes. I hope to shoot some videos soon of this splitter in action just to show people. The website really needs to update their video. Maybe I could sell them one.
/ Log Splitter Add On Idea Help #9
Here are the pictures. Ask away if you need any more information or pictures. The whole table is attached to angle iron that is bolted to the lower rail of the I-Beam. The second picture is where my trailer tongue bolts on at the end of the table.
/ Log Splitter Add On Idea Help #10
Wood can "explode off" with the wedge either on the ram or the end of the armature. I much prefer the wedge on the armature as if the wood does fly when splitting it is going away from me, not towards me. I have had splits fly as much as 6 ft. Another advantage is that the split wood has moved a bit away from the operator's position vice stacking up right there.
The only advantage to 'wedge on ram' that I have seen is the ability to use the ram to pull a stuck block off the wedge. The only commercial splitters I have seen with wedge on ram are the ones designed to tip up and use vertically. In that design there is no choice, the wedge has to be on the ram.
Harry K
JimR.....
Pictures are worth a thousand words......
Much appreciated, mine is a similar design & looks like angle will work fine. Is the table 1/8", 1/4" thick? Once again, Thanks!
Eric
/ Log Splitter Add On Idea Help #12
The table is only 1/16" thick. It appears to be holding up pretty well. I did have to weld up a few cracks in it when I bought it. 1/8" steel would have been a much better choice for the top.
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
UWS TBS-69 Truck...
PALLET OF JOHN DEERE WEIGHTS (A64278)
PALLET OF JOHN...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
UNUSED RAYTREE RMVR76-76" HYD VIBRATORY ROLLER (A65055)
UNUSED RAYTREE...
KING 3 BAR - 18 SHANK CHISEL PLOW, 3PT (A64278)
KING 3 BAR - 18...
