Log loader trailer swivel clevis hitch.
   / Log loader trailer swivel clevis hitch. #1
rasorbackq
Platinum Member
Springfield Nova Scotia Canada
Branson 4720
Morning guys
Just bought a used Patu 400 trailer . Previous owner used horses to pull trailer around. I don't have horses as per say but have 47 of them all wrapped up into a Branson tractor frame. So my plan from the purchase was to remove the set of wheels , axle and horse draw bar to convert back to clevis hitch . All I'm missing is the clevis. The hole that the round clevis fits through is 1 1/2 " by 5" long. So I know I need to weld flat stock top and bottom on the 1 1/2" round stock to form the clevis.
Couple questions .
What size flat stock??? I have 1/2" material . Will that be heavy enough? trailer is 7-8 ton rating
How do I fab it to attach it to original swivel and not pull out?. Drill a hole and insert a bolt to allow the hitch to rotate. One that I seen they drilled a hole straight into the length of the hitch and threaded a bolt and larger rounded plate . There must have been more to it as I can't see just threads holding the pulling action of the trailer. I will be fabbing it but not welding it so the option of inserting the hitch and welding a stopper is not an option. I have built swivel hitches in the past and just used a bolt as a stop . Maybe I just need a larger bolt / pin this time.
What are your ideas?
   / Log loader trailer swivel clevis hitch. #2
You'll probably get better responses if you ppost a picture or two.
   / Log loader trailer swivel clevis hitch. #3
There are pictures of a Patu 400 trailer set up for tractor pull on Google.
   / Log loader trailer swivel clevis hitch. #7
Looking at the online pics, which aren't very good, it appears it's intended to use a pintle hitch, with the ring mounted in that round hole that's empty... If that hole is is at a proper height to match your tractor's hitch, you could make a clevis style hitch for it.
I'd suggest using some 1.5" Cold Rolled Round for the through-tongue part. And use 5/8" x 2" Cold Rolled Flat for the upper and lower parts of the clevis. (1/2" A36 plate will probably not break, but the holes will elongate quite rapidly.) If you can't find cold rolled flat in 5/8", then go with hot rolled in 3/4" thickness. (Hot rolled is softer, but the added thickness will slow any wear.
Assuming this is a permanent mod, Just buy a nut (1-5/8"?) and two washers that will slide over the round stock. Put one washer at the front, as a bearing surface between the trailer frame and back of the clevis, and one at the back, then slide the nut on and weld behind it... Done. (I assume there's a grease fitting there somewhere, so if not, I'd drill a hole and tap one in, just to be able to grease it occasionally...)
Here's a nice picture I scribbled for you:
   / Log loader trailer swivel clevis hitch. #8
My guess is that you need to extend the tongue. It looks like the front of the trailer will hit the tractor tires.
A side view picture would help.
How wide is this?
   / Log loader trailer swivel clevis hitch. #9
Some pictures of similar Patu trailer tongues.
Bruce
   / Log loader trailer swivel clevis hitch. #10
Get a piece schd 80 pipe the outside diameter of the hole and long enough so the tractor clears. A large steel washer on each side of the swivel point with a couple of bolts/pins to hold them in place and weld a receiver on the other end. Might try and get a couple of zerks on the washers and swivel to grease. If the pipe doesn't seem strong enough weld a verticle plate on the bottom of the pipe.
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
HELI 5K FORKLIFT (A58214)
HELI 5K FORKLIFT...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
2016 Chevrolet Silverado 2500 HD 4x4 Crew Cab Pickup Truck (A55973)
2016 Chevrolet...
2020 CATERPILLAR 259D3 SKID STEER (A52709)
2020 CATERPILLAR...
2008 TEREX TRAILER LIGHT TOWER (A58214)
2008 TEREX TRAILER...
