Loctite Red 680. Is there a substitute?
   / Loctite Red 680. Is there a substitute? #1
dturnmire
N. Georgia
Pt-180
I have a Pt-180 and had to take apart the brush cutter and put it back together. Terry at Power Trac told me I needed to use Loctite Red 271 to connect it to the drive shaft but that didn't hold so I have been using Shoo Goo which has worked fine this year before finally giving way.
Blackwell said the correct product is Loctite 680 but no one carries it except one place that said they would special order it with a cost of $31.00 (they don't carry the smaller tubes). I can't even find it on the internet. Is there a generic or different brand that is designed for shafts and bearings? Thanks.
   / Loctite Red 680. Is there a substitute? #2
http://tds.loctite.com/tds5/docs/680-EN.PDF
Here is a Link to the specs on Loctite 680. At least you can compare any possible replacements.
I was able to search on "Loctite" & "680" and got the loctite site as a result.
I can buy loctite at the napa store in a local town, they seem to stock different stuff then the napa stores in OKC. It may be a privately owned store as opposed to a Napa company store.
Maybe try them in your area.
   / Loctite Red 680. Is there a substitute? #3
Remember this, your connection at both ends has to be perfectly clean and dry.
Thanks Piedmont. I have tried every automotive store in Chattanooga as well as hardware stores. I will probably get the $31.00 bottle and at least have it for future use. I was thinking there might be a similar product designed for the same thing. I wish they had just drilled a hole for a bolt to hold it on. That would have been simple enough.
   / Loctite Red 680. Is there a substitute? #5
Loctite 680 is a special blend of loctite. There are several loctite's on the market. 680 is expensive. Grainger.com carries it but it is high priced and for special purpose use on shafts etc. Go to their site and do a search for loctite. that will bring up all types they sell. You can read about each one and its uses. maybe you can find something cheaper besides 680 that will do what you need it to do.
   / Loctite Red 680. Is there a substitute? #6
mcmaster.com has Loctite 680 in sizes ranging from .5ml at $1.52 up to 250ml at $119.86. Go to the website, search "loctite 680" and the correct page will open. You can then click on the part number for the size you want.
Hope this helps
Gravy
   / Loctite Red 680. Is there a substitute? #7
Try ebay. Auction number 260009506459.
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A55852)
2016 Ford F-550...
1991 John Deere 4955 (A53317)
1991 John Deere...
CAT CS563 (A47477)
CAT CS563 (A47477)
UNUSED FUTURE POLYTHYLENE PROTECTION PAD (12 PCS) (A57193)
UNUSED FUTURE...
2022 Club Car Tempo Golf Cart (A55853)
2022 Club Car...
2020 Bobcat T550 Compact Track Loader Skid Steer (A55851)
2020 Bobcat T550...
