LockNLube for Kioti RX7320 - Which One?
   / LockNLube for Kioti RX7320 - Which One? #1
OrangeAgain
Albany, Vermont 05820
2015 Kioti RX7320PC, 1983 Kubota L275 4WD, 1981 John Deere 2440 2WD row crop tractor
I'm thinking of getting a LockNLube grease gun coupler to grease my RX7320 and other machines. LockNLube offers a standard size and an XL size for recessed Zerks.
Standard Size, $29.95 - https://www.amazon.com/LockNLube-fi...rds=locknlube&qid=1567419838&s=gateway&sr=8-4
XL Size, $39.95 - https://www.amazon.com/LockNLube-Gr...rds=locknlube&qid=1567419838&s=gateway&sr=8-9
Do I need the XL size for any of the Zerks on my RX7320?
Any issues with the LockNLube?
Any better competitors of LockNLube grease couplers?
   / LockNLube for Kioti RX7320 - Which One? #2
I have the standard size for my Kubota. It has worked everywhere that I have tried to lube with the exception of the U-joints on the PTO shaft for the rotary mower. I had to buy the angle head to get into those spots.
   / LockNLube for Kioti RX7320 - Which One? #3
I have the standard one. Has worked well for tractor and vehicles. The only time I use anything different is when I put a grease needle on.
   / LockNLube for Kioti RX7320 - Which One? #4
Although mine is not a Kioti (Kubota GL6060) I have the standard LnL. It will do all the fittings except 1 on the lower swing of the back hoe. It is too long so the longer one would only be worse. I have 2 grease guns so I just use the standard coupler on that fitting. I like that I don't have to fight to get the coupler off the fitting with the LnL. If you don't have any really recessed fittings the standard coupler will probably work for you. Hopefully someone with the same tractor will chime in with their experience.
   / LockNLube for Kioti RX7320 - Which One? #5
Standard one is what I use. Works great! Wish it weren't so expensive though...
   / LockNLube for Kioti RX7320 - Which One? #6
Been using mine for a while now, it's not working all that well anymore, I would have thought it would have lasted longer without a rebuild..
S/N: 5D121002416 (A55787)
S/N: 5D121002416...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2017 Ford F-150 Crew Cab Pickup Truck with Liftgate (A55852)
2017 Ford F-150...
2019 BOBCAT T595 SKID STEER (A52707)
2019 BOBCAT T595...
1977 Ford F-100 Ext. Cab Pickup Truck (A53422)
1977 Ford F-100...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A57024)
2021 John Deere...
