locknlube cupler for a grease gun
   / locknlube cupler for a grease gun #241
Since there are pictures on this thread of my lever gun with a hose ( https://www.tractorbynet.com/forums...upler-grease-gun-post4066442.html#post4066442 ), I will post the latest version with a 4' long hose:
   / locknlube cupler for a grease gun #242
I picked up one recently and really like it. Makes lubing the FEL BH and tractor much easier. I got a 90 degree adapter I haven't tried yet.
   / locknlube cupler for a grease gun #243
The LNL is one of those things that after you use it you think to yourself, "Why do they even sell grease guns with the fittings on them that they do"?? It's SO MUCH better. It's not a little better, it's like 1/2 (maybe less) time to grease my entire tractor using a LNL compared to the standard fittings. I'm with you guys, 30 bucks is more than my whole grease gun cost! I'd be shocked if the manufacturing cost on the LNL is over 5 bucks, but hey, that's capitalism, guy came up with a fantastic solution to a real PITA for those of us who are trying to attach/detach from 100's a zerks a few times a year. Good for him. If you're anything like me, the 30 bucks will be a distant memory when you start using this thing, it's just "the way it should be". Everything works naturally, it's so fast, it's just a joy to use after you've suffered with a regular fitting for, well, your entire life!
Frankly, over a long enough period of time, this thing will probably save me money because I'm not going to think "Man, I really should lube that zerk, but.. It'll be fine until next week" and then wind up with a worn bearing that would have been avoided if I hadn't been dreaming up excuses to not have my stupid grease gun fitting get stuck on that zerk and bang my knuckles getting it off. I'm probably greasing 2-3X as often now, and if I see something that even seems a little dry, I'll just swing by the barn and put a pump or 2 of grease in. Easy as can be, 2 seconds to connect, 2 to disconnect, a pump or 2.. 15 seconds, max, and I know it's not going to be a wrestling match going on or off.
Thanks for the advice on this one guys, just wanted to pass along my experience, great suggestion! If you're greasing even dozens of zerks, just get it. You'll be happy you did!
   / locknlube cupler for a grease gun #244
   / locknlube cupler for a grease gun #245
I just bought a LNL, have not tried it yet. Not sure where i put it.
   / locknlube cupler for a grease gun #246
They’re now offering a longer version as well.
LockNLube Grease Coupler XL | LockNLube - LOCKNLUBE
Combine a pneumatic grease gun and a LocknLube coupler and greasing becomes quick and easy so ...... you’ll do it more.
I’ve got two of them.
I picked the long one up for my new electric gun. I'm not sure of the value at double the price of the normal one. I was hoping it would make PTO shaft U joint greasing easier. It might, but not by much. It makes getting on a few other zerks harder as well. Havent put my original shorter LnL back on yet, but might do that at some point.
   / locknlube cupler for a grease gun #247
The longer one is $40, the standard one is $30? Not sure how that’s “double the price”?
   / locknlube cupler for a grease gun #248
A couple of years ago the wife bought me a DeWalt powered grease gun for Xmas. I used to hate greasing, now, between the LNL and power gun I'm looking for things to grease. It's mazing how it's changed my attitude about greasing now.
DEWFPO
   / locknlube cupler for a grease gun #249
I gave my LnL to Murph. He gave a walmart gift card which I used to buy some beer. We're both happy. :)
   / locknlube cupler for a grease gun #250
How do you like the coupling one?
Been researching for a coupler with my new to me bobcat. my d6 is easy enough.
2021 SELLICK S80J4E-4PS ROUGH TERRAIN FORKLIFT (A51242)
2021 SELLICK...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2019 CATERPILLAR 308 CR EXCAVATOR (A51242)
2019 CATERPILLAR...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2015 Hamm H7i VR-3 Single Drum Vibratory Soil Compactor (A49346)
2015 Hamm H7i VR-3...
