MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 67,314
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
That's the easy way. What also interests me are the mechanical ways. And not by accidentally pressing a button.
I could mention a few others than I didn't previously mention but was fishing for other ideas to morph this thread.
Sometimes I’ll bugger up the treads on the part that’s through the nut so it can’t back off.
Typical you...............![]()
Yes sir! How about a quick little spot weld that can be broken with a twist.
A follow-up on the mysterious two closed threads back on 09/02. I found that if I'm logged in to TBN, and scroll through a list of threads, if my left thumb bounces on the envelope icons, the iPad touchscreen saw it as a double click. Double clicking on an envelope when you have moderator powers toggles state between closed and opened threads, depending on it's current state. I knew this on PC, but did not on iPad. I figured it out when I went to read a thread, bumped the envelope instead of the link, and it closed on me. So I'm pretty sure it was me that closed those two. I'll be a bit more careful where my left thumb rides on the screen and apologize for the inconvenience.
Just thought some of you would like to know that those two were not intentional. All the others, pretty much so.![]()
I'm still hoping for thread drift here to talk about locking threads. :laughing:
Now I'm having a problem pruning threads. I have a report into the admins on that as well. I'd rather prune them and reopen if at all possible.
Thread drift story time.....
Years ago I was helping and elderly gentleman change the cutting edges on the grader he ran. They are heavy and his old grader didn't have the ability to rotate the moldboard outside the grader so they had to be changed laying on the ground. When we got the new ones on and the bolts tight he grabbed a ball peen hammer and started beating on the exposed bolt threads. I asked why? He said so they don't come loose. I asked, doesn't that make them hard to remove when you need to rotate the cutters? He looked at me like I was an idiot. Then said, who rotates cutters??? :confused3:
I rotate mine at least 10 times before I have them worn out.![]()
The more you know... the more you know you don't know!
Speaking of locked threads... .
