Locked up Rear Wheel
/ Locked up Rear Wheel #1
tke381
When I leave my YM1601 sitting for 10 minutes or more, the rear right wheel locks up. It doesn't matter if the brake is engaged or not. Mashing down the differential lock gets it unstuck. Any ideas on what causes this? Any idea how to fix it? /forums/images/graemlins/confused.gif
/ Locked up Rear Wheel #2
It may be a brake spring broken and the shoe is binding on the drum.
Can I get to that through the plate up and to the front from the axle?
/ Locked up Rear Wheel #4
Yes, that would be where your brake adjustment rod connects (from the pedal). The brakes would be where I start, and if they look ok you may want to jack up your tractor and spin the rear wheels and check for badly worn axle bearings.
Let us know what you find....and welcome to TBN.
Mark
/ Locked up Rear Wheel #5
"Mashing down the differential lock gets it unstuck."
That just causes the differential to overcome the problem. It does sound like a sticking brake.
Thanks Norm, thanks Mark
Yeah the diff overcomes the problem, but it sounds horrible and I don't want to think of the damage it is causing. I will take off the wheel and check it out today and see what I find. The rear alxe bearing appear to be OK. Hopefully something simple /forums/images/graemlins/smirk.gif
/ Locked up Rear Wheel #7
Rear end gear tooth chipped or broken.
Could be brakes but they normally won't be as noisy as you are describing.
I would check them first but I doubt thats the problem.
KO
2019 John Deere 9470RX Tractor (A63111)
2019 John Deere...
2016 Sky Jack SJ8831RT 31ft 4x4 Rough Terrain Scissor Lift (A61572)
2016 Sky Jack...
2008 Trail- Eze Tilt Triaxle, 42' Deck/10' Neck (A62679)
2008 Trail- Eze...
UNUSED WOLVERINE 6' FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2022 EZ-GO ELITE...
2012 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2012 Ford F-150...
