Location of TN55 3-point rate of drop valve ?
   / Location of TN55 3-point rate of drop valve ? #1
hosspuller
Piedmont Triad, NC
Didn't intend to have a Deere fleet - it just happened 310C, F915,102, 5200 & 5065E
A friend has a TN55. His complaint is the slow descent of the 3 point. Is there a rate of drop valve on this machine he doesn't know about?
Thanks for your replies ...
   / Location of TN55 3-point rate of drop valve ? #2
There is a drop rate valve located in the hitch valve housing; nearly impossible to access without removing the hitch cover from the rear axle.
Try adjusting the Lift-O-Matic cable shorter by a full turn or so. Adjust at the cable end near where the hitch position control linkage enters the hitch cover.
Thanks for the reply ... I'll pass the tip on.
2019 KUBOTA L39 BACKHOE (A51246)
2019 KUBOTA L39...
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
1994 International 4800 DT 466 Pole/Drill Truck (A52384)
1994 International...
FORD 3610 TRACTOR (A51247)
FORD 3610 TRACTOR...
2022 Freighliner M2 4 Car Rollback (A53117)
2022 Freighliner...
