Location of TN55 3-point rate of drop valve ?
   / Location of TN55 3-point rate of drop valve ? #1
hosspuller
Veteran Member
Piedmont Triad, NC
Didn't intend to have a Deere fleet - it just happened 310C, F915,102, 5200 & 5065E
A friend has a TN55. His complaint is the slow descent of the 3 point. Is there a rate of drop valve on this machine he doesn't know about?
Thanks for your replies ...
   / Location of TN55 3-point rate of drop valve ? #2
There is a drop rate valve located in the hitch valve housing; nearly impossible to access without removing the hitch cover from the rear axle.
Try adjusting the Lift-O-Matic cable shorter by a full turn or so. Adjust at the cable end near where the hitch position control linkage enters the hitch cover.
Thanks for the reply ... I'll pass the tip on.
2012 Acura TL Sedan (A51694)
2012 Acura TL...
2011 WABASH 53x102 DRY VAN (A53426)
2011 WABASH 53x102...
2016 Chevrolet Tahoe SUV (A52377)
2016 Chevrolet...
UNUSED LANDHONOR PHA-16-2C HYD HITCH ADAPTER (A51248)
UNUSED LANDHONOR...
2018 JOHN DEERE 5075GN LOT IDENTIFIER 128 (A53084)
2018 JOHN DEERE...
New Holland 1745 (A50123)
New Holland 1745...
