Locating a waterline leak.
   / Locating a waterline leak. #1
zzvyb6
Super Member
michigan
jd 1070
Hello All.
My barn water supply line is feed from my house well. The line is tee'd of from within the basement, so I can shut it off from inside the house without turning off water to the house. The basement line leaves the house to the barn about 7' below the ground. Then it's a 50 yard run to a tee valve, then to a hydrant and on to the barn. The depth there is about 5'. There is an obvious leak somewhere out there. In the past, a rock would pinch the line, a spring would rise up and I would dig it up there and patch it. This time the flow is much larger and no spring has pooled up. I obviously want to avoid trenching a new line out to the hydrant. I suspect the leak is due to a joint blowing out near the house instead of a rock cut. I'm open to any and all ideas on how to localize the problem. I've even considered blowing some high pressure air into the line to see if I can listen for it. What do the 'ex-spurts' say?
Thank you.
   / Locating a waterline leak. #2
Every water utility in the country has the high tech sound detectors to look for leaks. The machine looks like a walking stick. The worker walks along keeping the point near the ground and listening to his headphones. Ask to see if they will provide this service for you even though you are on a well. They might even be available for rental. It should take only a few minutes to find an active leak.
   / Locating a waterline leak. #3
I say that you are going to be digging a new line. Next time put the line into a 3" PVC schedule 40 pipe, and your life will be a lot easier. No rocks to contend with, and replacement is going to be very easy, if you ever need to replace it. My line from my well has been in PVC pipe for over 20 years, and no problems so far..... Knock on wood! :D
Dusty
   / Locating a waterline leak. #4
not every place in the country has a water utility.
   / Locating a waterline leak. #5
There must be some public water utility within 25 miles??? Even little towns of 500 people use public water, don't they? If not, then rental places might have them.
   / Locating a waterline leak. #6
Seems like that whe water would come to the surface somewhere. Even water leaks in the street come to the surface.
   / Locating a waterline leak. #7
The last thing you want is to have this leak next to your foundation (I know personally). It can really mess up your walls big time.
If you don't have any other choice, you might consider calling the local septic service in your area. I did for mine, and they came out with an optic cable/camera; stuffed it down the pipe and found the break based on how far the cable travelled when they viewed the break on the Mini-TV display. This may not work for a normal leak though - just brainstorming for ya.
   / Locating a waterline leak. #8
Being as deep as your line is, it's easy to understand that the leak could be traveling alon the pipe for some distance. I've heard stories of this happening for thousands of feet. If there is any sort of undground tunnel from rodents or an old rotted out root to just about anything, the water may never come to the surface.
The first thing I'd do is get a piece of 3/8 rebar and put a handle on one end to form a very tall T. Then start poking it into the ground every four feet to see if you can get a spot to let the water out. If you find water, that won't mean it's the right spot, just a good clue.
Keep doing the entire line to see what you find.
I'm hoping that there is an area of more preasure than any other areas. If you find a dozen places that you get water from, one will probably have more flow than the others.
If this doesn't work, you can either replace the entire line or play the 50/50 game. Dig down at the middle of the line. Cut it and cap both ends. Test to see which side is leaking, then do this again in the middle of that line. Keep doing it until you find the leak.
You didn't mention what the pipe is made out of or what size it is. For such a short run, and since you've had problems before, I might just run a new Schedule 40 line and be done with it.
I've wasted manydays looking for leaks and in the end just replaced the line in one day anyway. If I'd done that first, I'd have saved several days of frustration.
Good luck,
Eddie
   / Locating a waterline leak. #9
HOW long has this line been under ground?
   / Locating a waterline leak. #10
how far from the hydrant to the barn? or is the hydrant at the barn? maybe you can determine which side of the hydrant the leak is on.
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
2012 VOLVO BL70B BACKHOE (A51246)
2012 VOLVO BL70B...
2015 FORD F550 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F550 XL...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2019 Bobcat 3400 4x4 Utility Cart (A54811)
2019 Bobcat 3400...
