Front-End Loader locate pallet forks
   / locate pallet forks #1
jhoch
where can I pallet forks for a john deere 200x loader?
   / locate pallet forks #2
Artillian makes some of the best pallet forks for the 200cx/x loader. They are light and strong giving you more lifting capacity. Do you have a JDQA quick attach bucket? Hopefully you do, the bucket is held on with two lynch pins and can be removed in about a minute. If not a I believe that Artillian makes a pin-on pallet fork too.
Artillian Tractor Attachments
   / locate pallet forks #3
Nice machine you got there! Looks like you have plenty of ballast as well:thumbsup:
   / locate pallet forks #4
I have about 850 lbs of ballast on the back and the stump was about 1000 lbs. I cringe when I see people doing moderate to heavy lifting with nothing on the back, it is dangerous and the front axle is being overloaded.
   / locate pallet forks #5
You will never find me without something in the back. Even if that's just loaded tires. But when I'm doing heavy work there is something back there. It's one thing to have the front tires lifted of the ground and have the axel not wobbling but to lift those back tires off and the entire tractor tilts and you put it back on the ground and your heart rate suddenly doubles and you have a gooy mush in you pants. I've been there before, really don't want to do it again!
2018 Harley Davidson (A56859)
2018 Harley...
2017 Genie GTH-5519 (A53317)
2017 Genie...
207281 (A52708)
207281 (A52708)
DEUTZ MARATHON 60KW GENERATOR (A58216)
DEUTZ MARATHON...
(1) Multi-Trunked Non Fruiting Olive Tree w/ Military Barrel (A59225)
(1) Multi-Trunked...
2018 CATERPILLAR 289D SKID STEER (A52709)
2018 CATERPILLAR...
