Dealer Local dealer?
   / Local dealer? #1
econ
Thank you all for the responses to my other post, "Price check for NY". Wallace definitely has some great prices. I thought I start a new discussion about buying local or travelling a distance to get the tractor. I can pick up the kioti I am looking for locally (19 miles) for $850 more. Actually, it will be delivered for free and first oil change is free. So what. Big deal. I certainly can manage an oil change.
But, leads to another thought. Will local dealers generally perform warranty work on tractors bought somewhere else. I assume they do regular maintenance for a nice fee. Is there a lot of maintenance with the Kioti's. I am using an Ford 9N now...lots of maintenance and fiddling.
Any insight would be great. Thanks again.
   / Local dealer? #2
I believe that supporting your local dealer is a good thing.
When I was checking prices a Kubota dealer told me the 50 hr service would run $350.
So are you getting an oil change, or a 50 hr service?
   / Local dealer?
You are correct. 50 hr service. I assume it simply was an oil and filter change. Must be more for $350.
   / Local dealer? #4
That is a tough question. I ended up buying from the closest dealer. His price was not the rock bottom lowest, but it was within 250.00 dollars. Any Kioti dealer should repair your tractor under warranty. As far as price shopping goes, mostly everybody does that one way or the other. Alot of people price shop just to save a dollar. I price shop, but I also take into consideration the person or company that I'm buying from. I have paid more for some items just because I liked the person or the company I dealt with. Honestly though, not one dealer I talked to for about 6 to 8 months earned by business. All makes and models included here. The product sold it self and it just so happens my local dealer was competitive in pricing. I don't really expect any tractor to go in the shop for anything major. They are all built very good now in my opinion. There are some outstanding dealers out there such as Wallace and Depratt just to name a few, that deserve to charge accordingly for there outstanding service. If you happen to live near a dealer that is outstanding than that is a plus. If a outstanding dealer is farther away, then I say they deserve your business as long as it is a fair price. Just my opinion though.
   / Local dealer? #5
</font><font color="blue" class="small">( Must be more for $350. )</font>
Not sure what they were actually going to do for the $350.
I ended up with a CK20HST from a dealer 5 miles away. They were good people, and are also going to do the 50 hr for me also.
I was just trying to point out the free 50 hr might be worth something towards that $850 difference.
   / Local dealer?
I thought it was a tough question also. That is why I started it as a new thread. If the prices were within $250 dollars, I would not be asking. I would definitely go local. Have to support the local business. But, $800 to $1000 more, really makes you sit back and think about it.
I would like to know what service is done at 50hrs. Do they drain and change all the fluids? Or just oil and filters?
LOL...Buying a car is easier.
Thanks again for all your informative responses.
   / Local dealer? #7
From what I understand all the fluids and filters should be changed at the 50 hour service. Some of the dealers on here could give you a better answere I'm sure.
   / Local dealer? #8
We do the following....
Change engine oil and filter
Change hydro fluid and filter(s)
Change front axel fluid
go over all loader frame bolts
Go over all backhoe bolts
Check adjustment on clutch & brake
Drain clutch housing
Clean raidiator and prescreen
Inspect air filter
Check lug nuts
Check air preasure in tires
Check all lights
Check all saftey switches
Grease the whole machine replacing the ones that don't take grease
Test drive
clean machine
That is about 3 hours spent on a machine
That is usually around $350
   / Local dealer? #9
I have yet to have any warranty work done on my CK20HST which I bought in Jan 04, almost 350 hours. Loaders, backhoes etc. are made by other OEMs not Kioti. Some of those have had some problems from time to time. We've had reports here occasionally of small issues, but most are taken care of pretty quickly to the satisfaction of the buyer.
Kioti dealers are all required to provide nationwide warranty work, and most dealers would like to earn your local business, so, as a general rule I don't see any problem with buying from far away.
That said, consider the costs of getting an out-of-town purchase to you today in this atmosphere of HIGH fuel costs. If you go get it yourself, what will it cost? What will shipping to you cost? You may diminish the cost difference quickly once you know these costs.
John
   / Local dealer? #10
I have an 8N and do some tinkering with it also. My CK30hst has run perfectly without any tinkering except for keeping the fel and bh greased. I just completed my 50 hour service myself as per the manuals recommendations and it took me about four hours. What Wallace has written is right from the manual. Add up three filters, 6 quarts engine oil, four quarts front axle gear oil, and 7 1/2 gallons hydro fluid along with greasing everything and checking adjustments and the charge isn't really that bad. I just like to do my own work to save a few dollars and I also learn about the tractor.
As far as where to buy, I guess that is something you have to decide for yourself. $850 is definately something to think about.
2019 JCB 457 ZX T4F Articulated Wheel Loader (A49461)
2019 JCB 457 ZX...
2012 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2012 STEPHENS...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
WEATHERGUARD TOOLBOX (A50854)
WEATHERGUARD...
PETTIBONE B66 EXTENDO (A51222)
PETTIBONE B66...
Bus (A50323)
Bus (A50323)
