LoadMatch retro fit on JD 3720
/ LoadMatch retro fit on JD 3720 #1
Dan Hunter
Platinum Member
Enid, OK
2012 John Deere 3720 eHydro
With some time in the saddle, I'm wishing the tractor had load match but at the time I ordered the tractor I was ignorant to the utility it would provide. Reviewing the JD website is a waste of time because there's more outdated information than current. One link says it's standard on e-Hydro yet I have a blank where the switch should be.
Is it possible to add LoadMatch to my 2012 3720? If so, what does it entail...cost?
Thanks,
MIJI
/ LoadMatch retro fit on JD 3720 #2
Thanks,
MIJI
You had the same mentality as me. Yes you can ad it. I just priced the kit. It's already wired. Dealer quoted me 200 bucks for the kit and install. Computer needs to be reprogrammed. That's why it has to go to dealer. The kit is only the switches and you can install it yourself but like I said computer needs programmed.
BigMike50,
Thanks, I'll be contacting the dealer to order/setup an install today.
2017 Jacobsen 3551 HOURS (A56859)
2017 Jacobsen 3551...
(APPROX. 26) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 26) 4' X...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A61306)
1992 Talbert 70...
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2019 FREIGHTLINER...
2016 Dodge Journey SUV (A59231)
2016 Dodge Journey...
