Loading tires 3032E
   / Loading tires 3032E #1
Steve IA
Bronze Member
Clarke Co. Iowa
Ford 8N 1949, JD 3032e 2010
I know this has been discussed over and over, but obviously my 'search' skills are wanting and I can't find any of the discussions. I remember reading here of someone who had loaded the rear tires of his tractor by syphoning from a barrel into the tire, using a special valve that one would press the button of and periodically allow the air to escape from the tire relieving the pressure and allowing for more fluid to enter. I have the valve and 55 gallons of -20F windshield washer fluid and have attempted to load my tires. My problem is that when I let the air out of the tires to add fluid, the R-4 ( 15.00-19.5) tires come off the bead. After 5 gallons or so, I stopped and wrapped a cable come-along around the tire and cinched it up, and let the jack down a mite and after a couple of tries was able to get a bead seal again. I need some insight as to if someone has done this process before and what am I missing. Will using a drill pump overcome the pressure in the tire?
Thanks in advance for you help on this.
Steve
SouthIowa
   / Loading tires 3032E #2
I had a similar problem with my new 2520. When I first started I had the tractor jacked up with the tire a little off the ground. When I started putting the anti freeze in the weight of the fluid pulled down on the tire causing the bead to break. After cinching the tire with a ratchet strap I inflated the tire back to operating pressure and let it sit a little while. I lowered thee jack until the tire was holding just a little weight and let the air out again. I finished putting the antifreeze in the tire with the valve stem at the bottom. Connected my adapter to my water hose and started filling the tire with water until the tire had good pressure then jacked the tractor back up so I could turn the tire to get the valve stem to the top.
As for the other side I used lessons learned from the other side I know you are using a different method but maybe something in my story will help you overcome the challenge.
Gotter done using a drill pump. About 40 minutes / tire. Greatly improved traction. Thanks for your thoughts.
Steve
TRUCKING INFO (A50775)
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
2008 Ford F-150 Pickup Truck (A50860)
2008 Ford F-150...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
2020 Crane Carrier Co Side Loader Garbage Truck (A48081)
2020 Crane Carrier...
