Loading of Tires?
/ Loading of Tires? #1
sperry
Bronze Member
Southern, VT
TYM T300 HST, Kubota B7610HST, XMark Lazer Z 60"
I have a 33hp tractor with loader and am finding it very tippy. Because of this I am having the tires loaded. I purchased this tractor second hand with 41 hours on it. But can't figure why no loaded tires from original dealership. The rear tires I have are turf 13.6 x 16.
How much weight should I have put in each tire?
Should I use tubes with rim guard?
Should I load front tires also?
I like not tracking up the lawn, but this tractor seems too easy to tip. I tried to lift my tiller with the loader and was almost tipping over forward. Mowing my hillside is a little tippy feeling also.
___________________________________________________________________
TYM 300 HST KUBOTA 8200
/ Loading of Tires? #2
Have you considered putting the tiller on while doing loader work, or some other heavy attachment? Might save having to load the tires, if you don't want the extra weight on the yard.
David from jax
/ Loading of Tires?
I made a 3pt carry all box, loaded it up with rocks and have found it safer but not that handy. Are there charts available to give proper tire loading guidance? Thanks for your suggestion.
/ Loading of Tires? #4
In VT I think you'd be insane not to load the tires, front and back. Beautiful state, but seems not oversupplied with flat land.
/ Loading of Tires? #5
Usually tires are filled to a level above the top of the wheel. I have both the front and rear wheels filled. All four tires have tubes also.
Solo
/ Loading of Tires? #6
If you are going to load your tires, which I highly recommend, then look into a product called Rim Guard. Its completely organic, so if you have a failure and it leaks out of your tires, it wont kill your lawn/crop like calcium. Its also slightly heavier than calcium, so Ive been told. :D
/ Loading of Tires?
Well I went and did it today. Filled two back tires. It cost 189.00 per tire with rim guard and tubes, not sure how that matches to other areas?? They seemed like real good people. Sure noticed a differance but it was raining so no play time for now. Thanks to all for the comments.
TYM 300HST Loaded Tires 84.5 Hours
/ Loading of Tires? #8
Depending on how heavy you lift with your loader you might also want to invest in a decent sized box blade. It serves as a good counterweight and is useful for all kinds of things.
/ Loading of Tires? #9
I agree there. Loaded tires while necessary ae in no way sufficient for heavy loader work. Weight hung on 3 pt hitch is multipled by about 1.5 times equivalent weight on rims or loading in terms of effectiveness.
BTW I see no purpose in loading front tires unless you run no loader and only use heavy 3 pt equipment.
Andy
/ Loading of Tires? #10
This is just me, but when I bought my new tractor I chose not to load the tires.
Cost was the main factor. Not the initial cost of getting them loaded when new, but the ongoing cost of getting them reloaded every time I have a flat. I have some pretty rough land with metal junk everywhere from the previous owner; flat tires are a way of life. I just do all my loader work with the box blade on.
It also helps to not tear up my soft/wet ground when I'm mowing the field. Less weight means less compaction.
I plan on building a dedicated 3ph steel/concrete weight with a trailer hitch for doing loader work soon.
Again, that's just me; your circumstances and results may vary ;-)
Greg
/ Loading of Tires?
Finally had good weather and time to use my tractor yesterday. Loaded tires makes my tractor more safe. Also I loaded my tiller into the back of my truck without nose dives! It's a small price to pay to have my machine able to do more chores with increased safety!!!
TYM300HST
/ Loading of Tires? #12
Andy
I agree, but in addition to the box and FEL I do load the front tires - I'm on hills and will take every bit of low weight.
Foamed tires = no flats :) Great, except for price
2007 PETERBILT 335 SERVICE/LUBE TRUCK (INOPERABLE (A67714)
2007 PETERBILT 335...
PALLET OF TRASH PUMPS (A68842)
PALLET OF TRASH...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
2008 Generac SD100 T3 125kVA Standby Diesel Generator (A66734)
2008 Generac SD100...
2013 WACKER NEUSON  TLN8 LIGHT PLANT (A67714)
2013 WACKER NEUSON...
2012 CHEVROLET SILVERADO 1500 (INOPERABLE) (A67714)
2012 CHEVROLET...
