Loading car on trailer
   / Loading car on trailer #1
SpotsyMatt
Spotsylvania County, VA
NH TC45
This is mildly off-topic but involves my NH tractor so I thought it might be the place to post it.
I've got a car that needs to get loaded on a trailer (a guy is buying it from me). The car weighs 2800 pounds and can't be driven up onto the ramp as the engine is dead.
Don't have a winch but was hoping to use my NH TC45 to do pull it up onto the trailer somehow. Hadn't done this before and wanted to get some advice from those more experienced and wiser than I.
Should I be able to pull it up onto the trailer? If so, how would you do it?
Thanks!
Matt
   / Loading car on trailer #2
I've done this a couple times. The first time, a friend and I just pushed it onto the trailer. Not the easiest or safest approach, but it worked. Of course, one person in the car to hit the brakes quickly so that it didnt roll backwards down the ramps. Maybe you can put a buffer (old tire?) between the car and your tractor (or a truck, car, etc) and push it up the ramps.
The second time, we positioned the trailer downhill from the car and let gravity do most of the work for us.
Keith
   / Loading car on trailer #3
Matt, the only problem I'd see would be keeping the cable routed in the right direction or angle. I'm assuming the trailer will be hooked up to the towing vehicle which will keep you from lining the tractor up with the front of the trailer. The only time I had to load a non-running vehicle was putting Chevy Suburban onto a 16' trailer and we used a come-along for that job.
   / Loading car on trailer #4
a come-a-long would work.
The tractor would work, but you would have to have the trailer disconnected from the towing vehicle. This would cause the trailer to come up at the tongue when the car starts to go on the trailer. Could be very dangerous. Unless you have some sort of pulley system, you could have the tractor at a right angle to the trailer, and pull it on.
Like was said above, get a few people to help push it up, or use gravity to help get it on the trailer. Done both of these before with success.
I have since went and bought a very cheap portable winch (Master Lock 12V DC Portable Winch — 2000-Lb. Capacity, Model# 2953AT | 1,000 - 2,900 Lb. Capacity | Northern Tool + Equipment) which works very well, in multiple places.
   / Loading car on trailer #5
Let's see...
- jack knife the trailer so you can tow it straight on from the front.
- get a snatch block and fasten it to the front of the trailer so you pull it on from an angle
- do like one suggestion and park the trailer down hill so you can roll it on (easy, but what fun is that? :D )
- Just push it on with the bucket! (Get paid first!) :)
   / Loading car on trailer #6
I'd come-along it.. or use a farm jack as a puller.. might be safer.. etc.
soundguy
   / Loading car on trailer #7
Probably a long shot but does the car have a trailer hitch? We loaded a full size non-running pickup on my 18' trailer by pushing on the trailer ball. Bill C
   / Loading car on trailer #8
Hook a chain to the front corner of the vehicle and run the tractor up along side the tow vehicle & chain to the drawbar, keep the angle shallow and as long as the loading vehicle tires roll & not skid it will pull up the trailer easy.
Getting behind a rolling load on a slope or detaching the trailer from tow vehicle while loading are bad ideas in my book.
Thanks for all the ideas.
Funniest one was sent to me via e-mail:
"Fix the car, drive it up on the trailer."
Now, why didn't *I* think of that? ;-)
   / Loading car on trailer #10
One way if you have to unhook the trailer from the tow vehicle. Block all four corners of the trailer so it doesn't lift the front as you pull in onto the back. After, just crank the front up off the blocks, and pull them out. Hook up and then pull forward to drive off the rear blocks.
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2017 JOHN DEERE 8270R LOT NUMBER 189 (A53084)
2017 JOHN DEERE...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
2025 New/Unused LandHero 40 Gallon 2-Stage Air Compressor (A51573)
2025 New/Unused...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
ASSET DESCRIPTIONS & CONDITION (A52577)
ASSET DESCRIPTIONS...
