Loading 2520 with MM Mower
   / Loading 2520 with MM Mower
Thanks for the suggestions. The mower has always mowed level, so I have never messed with the adjustments. I will give that a try. Using a hill is an option at home, but I may not have that option elsewhere.
I will give the boards a try. I think I'm still going to have to replace the 5' ramps, but I don't want to buy ones any longer than I need.
   / Loading 2520 with MM Mower #12
Look at the "up-stop" first. Its on the right side frame of the tractor near the front of the mower deck. There is literally a piece of flat steel either sticking down from the frame, or up from the mow deck and that is what stops the mow deck from going up too high. Of course you want the mow deck raising almost all the way until that upstop hits, so check that first, thats super simple to check and that is as hi as you can lift you deck , so u will know if its worth adjusting it or not.
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52707)
(INOP) 2019 KUBOTA...
2018 ISUZU NPR 16FT BOX TRUCK (A58017)
2018 ISUZU NPR...
2019 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A58017)
2019 FREIGHTLINER...
NEW Skid Steer 72'' Sickle Bar Mower (A59000)
NEW Skid Steer...
MACK T/A DUMP TRUCK (A58375)
MACK T/A DUMP...
