loaders
   / loaders #2
What's that mean? Are they for sale? And if so, where?
   / loaders #4
Fellow TBN member, kd5hnw installed a coldwater loader on a yanmar I believe. Did quite a post on it with bunch of pics too....
Ease of install, happy with end results:D
   / loaders
I see you have a jd790 with a loader. i hope to get a jd790 soon.then i will have 790 loader for $1800 to.if anyone by hoquiam wa has a 790 i will put it on your tractor for $1650.
   / loaders #6
That comes to about $3450...might as well buy the real thing (300x loader) for that. Or is that $1650 the installed price?
I see your site doesn't list any specs for the loaders of backhoes. I also noted the bucket dump/curl cylinder has one center hydraulic cylinder. I'm assuming these items are for light duty only (500-600 lbs or less)?
Also, the first post stated these were made in the US? Do you make the loaders/backhoes or buy them? If you buy them, who builds them for you?
   / loaders #8
Sorry but not impressed by the pictures.
Neither am I, but to be fair, these loaders could be a viable option for older CUTs (1970's through 1990) since factory loaders are rarer then hen's teeth.
   / loaders
the loader will pick up over a 1000lb.i tell people 900lb so they don"t brerk there tractors.my cylinder are 2"col.load is 7854 lbs. i think you will need more tractor then a jd790.by the way how do you come up with $3450? i do a lot of jd850 loader now for $1800 installed are shipped.the $1650 jd790 installed was the frist one so i can make a pattern. then it will be 1800$ jd790 850 650 there are a lot of them.we have been making loader for 12yr but for gray tractors that we wholesale.think what runs like a yanmar
   / loaders #10
Re-read my post...I specifically asked if the $1650 was the installed price.
As I wrote, those loaders are probably good for light duty (500-600 lbs)...there's more to the loader design then the cylinder specs. Just my opinion, but they look a bit light weight (the rectangular tubing and such).
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
JOHN DEERE 444-624 - 60" LOADER FORKS (A52705)
JOHN DEERE 444-624...
2022 FORD ESCAPE 4 DOOR SUV (A54607)
2022 FORD ESCAPE 4...
2002 Wacker RD11A Tandem Smooth Drum Roller (A54811)
2002 Wacker RD11A...
JLG 1255 Telehandler (A55218)
JLG 1255...
