loaders
/ loaders #2
What's that mean? Are they for sale? And if so, where?
/ loaders #4
Fellow TBN member, kd5hnw installed a coldwater loader on a yanmar I believe. Did quite a post on it with bunch of pics too....
Ease of install, happy with end results:D
/ loaders
I see you have a jd790 with a loader. i hope to get a jd790 soon.then i will have 790 loader for $1800 to.if anyone by hoquiam wa has a 790 i will put it on your tractor for $1650.
/ loaders #6
That comes to about $3450...might as well buy the real thing (300x loader) for that. Or is that $1650 the installed price?
I see your site doesn't list any specs for the loaders of backhoes. I also noted the bucket dump/curl cylinder has one center hydraulic cylinder. I'm assuming these items are for light duty only (500-600 lbs or less)?
Also, the first post stated these were made in the US? Do you make the loaders/backhoes or buy them? If you buy them, who builds them for you?
/ loaders #8
Sorry but not impressed by the pictures.
Neither am I, but to be fair, these loaders could be a viable option for older CUTs (1970's through 1990) since factory loaders are rarer then hen's teeth.
/ loaders
the loader will pick up over a 1000lb.i tell people 900lb so they don"t brerk there tractors.my cylinder are 2"col.load is 7854 lbs. i think you will need more tractor then a jd790.by the way how do you come up with $3450? i do a lot of jd850 loader now for $1800 installed are shipped.the $1650 jd790 installed was the frist one so i can make a pattern. then it will be 1800$ jd790 850 650 there are a lot of them.we have been making loader for 12yr but for gray tractors that we wholesale.think what runs like a yanmar
/ loaders #10
Re-read my post...I specifically asked if the $1650 was the installed price.
As I wrote, those loaders are probably good for light duty (500-600 lbs)...there's more to the loader design then the cylinder specs. Just my opinion, but they look a bit light weight (the rectangular tubing and such).
/ loaders
Square tubing is visually smaller but structurally it is very strong. We use between 3/16, and 3/8 material on the loader.
Here is a photo for reference. This is a Yanmar YM2000, lifting a Kubota B7100. A quick online search shows the Kubota at B7100 1,080lbs.
This is not to say our loader is indestructible but, in the wrong hands you can damage any factory loader.
The $1650 is the installed price for only the JD750. Normally they are $1800 installed. Sorry for the confusion.
/ loaders #12
As I wrote, I'd still stick with a factory loader if available, but you do provide an alternative to other aftermarket loaders.
You should post in the classifieds-dealer forum. You might get more takers. There's some, but not a lot of older Deere CUT owners on this forum (older referring to the tractor, of course).
/ loaders
that's fine and you can have a opinion. but i will give you the facts on my loaders. 500 to 600 is an opinion and not the fact.the b7100 is 1080lbs thats a fact you can SEE. i know i will never sell my loader to everyone.but i do sell a lot of jd650 and 850 there are a lot of them out there. we have at any time 60 to 125 tractors in stock.so i see a lot of bent loaders that are factory made.what i am saying is i have 7 guys working in the USA making loaders in hoquiam wa. making loaders for $1800 that's a good deal for any one that we can help on any tractor.we are now an advertiser on tbn.so there is a jd 850 loader and pictures and a b7100 kubota in the classifieds.thank you
/ loaders #14
I have been nothing but VERY HAPPY with my Coldwater FEL. 4 months of hard work later I am still impressed with the FEL's durability and strength - KD5HNW (aka - james in alabama)
2019 MACK ANTHEM 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 MACK ANTHEM...
1999 John Deere 7810 (A60462)
1999 John Deere...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
2016 Cadillac CTS Sedan (A61574)
2016 Cadillac CTS...
2011 Honda Civic Coupe (A61574)
2011 Honda Civic...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
