Loaders using rear remotes
   / Loaders using rear remotes #1
LittleBittyBigJohn
Veteran Member
Central Arkansas
John Deere 1025R, Kubota ZD1211
   / Loaders using rear remotes #2
Probably works just like the old Deere style controls. Probably not really convenient location though, possibly slow flow.
   / Loaders using rear remotes #3
Flow isn't likely to be different than a joystick running off the same pump. It all boils down to how convenient (or inconvenient) the control levers are to reach and use.
   / Loaders using rear remotes #4
It used to be very common,
with two remotes it worked just fine.
One other way that was common was to use one tractor remote up to a pair of loader valves.
Something else to be aware of depending on the used tractor brand and model
some will be closed center systems, many will be open center.
Most will have a smaller pump then newer tractors of the same size and hp.
   / Loaders using rear remotes #5
Yep. I plan to route hoses from my rear remote for the 3rd function to yaw the front snow blade. Not most handy idea but "good enough" for the occasional snow plowing.
I guess adding a power beyond and a loader valve would be tractor dependent then? Maybe you can't do that with all of them?
   / Loaders using rear remotes #7
It's easy enough to do on a John Deere. Just tap into the pressure line and by a filter housing adapter and dump into the hydraulic oil filter.
   / Loaders using rear remotes #8
As long as the Deere is closed center
   / Loaders using rear remotes #9
That is true for some Deeres, certainly not all, and certainly not on anything built after the early 1990's.
   / Loaders using rear remotes #10
My JD 2030 has return to filter housing kit from the two rear SCVs. I was told it was an option for using the rear SCVs for a loader. It did not have loader when I bought it.
Normally the SCVs returned to the side of the rockshaft housing.
2015 FREIGHTLINER CASCADIA DAYCAB (A50854)
2015 FREIGHTLINER...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
2013 Chevrolet Cruze LS Sedan (A50324)
2013 Chevrolet...
H & S High Capacity Hayrake (A50515)
H & S High...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
