Loaders using rear remotes
/ Loaders using rear remotes #1
LittleBittyBigJohn
Central Arkansas
John Deere 1025R, Kubota ZD1211
/ Loaders using rear remotes #2
Probably works just like the old Deere style controls. Probably not really convenient location though, possibly slow flow.
/ Loaders using rear remotes #3
Flow isn't likely to be different than a joystick running off the same pump. It all boils down to how convenient (or inconvenient) the control levers are to reach and use.
/ Loaders using rear remotes #4
It used to be very common,
with two remotes it worked just fine.
One other way that was common was to use one tractor remote up to a pair of loader valves.
Something else to be aware of depending on the used tractor brand and model
some will be closed center systems, many will be open center.
Most will have a smaller pump then newer tractors of the same size and hp.
/ Loaders using rear remotes #5
Yep. I plan to route hoses from my rear remote for the 3rd function to yaw the front snow blade. Not most handy idea but "good enough" for the occasional snow plowing.
I guess adding a power beyond and a loader valve would be tractor dependent then? Maybe you can't do that with all of them?
/ Loaders using rear remotes #7
It's easy enough to do on a John Deere. Just tap into the pressure line and by a filter housing adapter and dump into the hydraulic oil filter.
/ Loaders using rear remotes #8
As long as the Deere is closed center
/ Loaders using rear remotes #9
That is true for some Deeres, certainly not all, and certainly not on anything built after the early 1990's.
/ Loaders using rear remotes #10
My JD 2030 has return to filter housing kit from the two rear SCVs. I was told it was an option for using the rear SCVs for a loader. It did not have loader when I bought it.
Normally the SCVs returned to the side of the rockshaft housing.
/ Loaders using rear remotes #11
If I remember correctly, Deere initially used open center hydraulics, introduced some closed center models in 1960 with the 3010/4010/5010, added more closed center models with the 20, 30 and 40 series, and then by 1980, essentially everything Deere themselves made was closed center. A 2030 is closed center. However, the Yanmar-made compacts were open center. Deere went back to open center in the 5000 utility tractors in 1993 and all 5 series units are open center. The 6000 series has a mix but the 6D and 6E are open center, 4 cylinder 6x30s and 6Ms can be had either way, and pretty much anything 6 cylinder was and is closed center.
Putting a power beyond on an open center Deere involves removing three pipe plugs and plumbing in 3 lines. This is how Deere uses a mid-mount loader valve, it's run off of the power beyond.
Running a loader off of rear remotes was commonly done in the pre-loader-joystick days if the tractor had two rear remotes. You would use the tractor's spool valves to control the loader. If it did not have two remotes, the power beyond was used to feed a set of spool valves mounted to the loader, which was not generally considered removable. Later on the two spool valves became a joystick, and then after that the tractor manufacturers started to use their own tractor-mounted joysticks to control remotes. In the 1990s when tractor mounted joysticks were new, some tractors used the joystick to control the rear remotes which were then connected to the loader, and some used the then-brand-new separate mid-mounted remotes as we would use today.
/ Loaders using rear remotes #12
The concept of a return in the filter cover was limited to pure high pressure closed center systems used from 1960 till about 1990. That style return was not used on any open center or CCLS/PFC systems during that period or after.
/ Loaders using rear remotes #13
Loaders that run off the rear remotes were a cheaper way to connect the loader and use existing controls, prior to the joystick era it made for a much cleaner installation especially on a cab tractor. If the remote levers are comfortable to use then no worries, biggest drawback is it ties up your valves if you want to use the remotes for something else with the loader mounted.
10.5' Telescoping Ladder (A66408)
10.5' Telescoping...
2020 GMC AT4 CREW CAB TRUCK (A60430)
2020 GMC AT4 CREW...
20' Reids Trailer (A62613)
20' Reids Trailer...
26 ft trailer 20 ft bed (A61567)
26 ft trailer 20...
2019 GMC Sierra 2500,4x4 (A62679)
2019 GMC Sierra...
2011 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A64556)
2011 Chevrolet...
