Front-End Loader Loader won't turn up or down. Will raise and lower.
   / Loader won't turn up or down. Will raise and lower. #1
barrlou
Magnolia, Texas
Kubotas -B7100 & L2600
I have a Kubota L2600 with a LB 400 loader. Just changed fluid and now it will not turn up or down. It will raise and lower. Any help would be appreciated. Also I知 looking for a diagram of the hydraulic hose routing off the control for the loader. Thanks
   / Loader won't turn up or down. Will raise and lower. #2
Double check your hyd. fluid level. Sounds like you have air in the lines.
Then raise the loader and hold the joystick in curl up function for several seconds then do the same for curl down. After several cycles you should be able to get the air out. They will self bleed by cycling.
If for some reason you removed the loader from the tractor the problem may be in the hyd. couplers. You may need to unhook them and reconnect them.
LOT LOCATIONS (A56138)
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
CONCORD CRE96018B CONVEYOR BELT (A52706)
CONCORD CRE96018B...
2018 FREIGHTLINER CASCADIA SLEEPER (A56138)
2018 FREIGHTLINER...
2018 FORD F-550 CAN AND CHASSIS (A55745)
2018 FORD F-550...
2022 John Deere 317G Track Loader (A53485)
2022 John Deere...
