Front-End Loader Loader won't turn up or down. Will raise and lower.
   / Loader won't turn up or down. Will raise and lower. #1
barrlou
Magnolia, Texas
Kubotas -B7100 & L2600
I have a Kubota L2600 with a LB 400 loader. Just changed fluid and now it will not turn up or down. It will raise and lower. Any help would be appreciated. Also I知 looking for a diagram of the hydraulic hose routing off the control for the loader. Thanks
   / Loader won't turn up or down. Will raise and lower. #2
Double check your hyd. fluid level. Sounds like you have air in the lines.
Then raise the loader and hold the joystick in curl up function for several seconds then do the same for curl down. After several cycles you should be able to get the air out. They will self bleed by cycling.
If for some reason you removed the loader from the tractor the problem may be in the hyd. couplers. You may need to unhook them and reconnect them.
Bale Ring (A50515)
Bale Ring (A50515)
Vicon RV1601 Round Baler (A50774)
Vicon RV1601 Round...
2007 Ford Expedition EL Limited 4x4 SUV (A50324)
2007 Ford...
RACCOON TAXIDERMY (A51243)
RACCOON TAXIDERMY...
1995 1063 Corn Head (A50514)
1995 1063 Corn...
2006 BOMAG BW5AS DOUBLE DRUM COMPACTOR (A51242)
2006 BOMAG BW5AS...
