Front-End Loader Loader won't detatch
   / Loader won't detatch #1
guykingii
Dallas GA
4110 John Deere
I have a 4110 John Deere w. a 410 loader. Loader won't detatch. Latch and latch plate retainer are in correct position. Loader will not lift off tractor frame. Could the spacer in the latch plate retainer be incorrectly installed? Or what else might be wrong?
   / Loader won't detatch #2
Welcome to the forum. You might get an answer if you ask in the john deere section.
   / Loader won't detatch #3
Im not quite sure if a 410 is the same as a 430 loader but, I have trouble with mine sometimes. I prop the lever up with a tarp strap and use a big adjustable to pop the front plate off.
   / Loader won't detatch #4
I have the same unit. Sometimes I have to give the front plate a little nudge with a flat bar to make it slide off. HTH
Jim
   / Loader won't detatch #5
Just put my loader back on--after 8 years, I finally learned that if you curl the bucket just a tiny bit(like I were to dump a load) the front plate comes off without any assistance from me.:thumbsup:
   / Loader won't detatch #6
to second what Pipestone said, on my 400 x and 300CX you have to roll the bucket-just get front tires just about off ground.
2021 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52141)
2021 FREIGHTLINER...
John Deere Gator XUV560S4 4x4 Utility Cart (A50322)
John Deere Gator...
2011 Kubota L3200 (A50120)
2011 Kubota L3200...
2017 Vermeer SC802 S/A Towable Stump Grinder (A50322)
2017 Vermeer SC802...
2022 Bobcat T770 Skidloader (RIDE AND DRIVE) (A50774)
2022 Bobcat T770...
2003 Pierce Tilt Cab Pumper Fire Truck (A50323)
2003 Pierce Tilt...
