loader trouble
   / loader trouble #1
tonlin
Ford/New Holland 1925
I recently bought a 1998 F/NH model 1925 with a 7308 loader. To make a long story short, the seller deceived and cheated me. Among many other problems, I have discovered this tractor's loader has been severely damaged (bent) and a poor repair job was done.
I really need some pictures of the front of the loader's support frame that is used to rest the loader on when it is removed. Also need pictures of the side frame where the latch handles go as well as the part of the latching mechanism underneath the frame. This is a quick attach loader that normally requires no tools to install/remove. However, thanks to the damage, this one has bolts holding it on. I want to return it to the correct form so it can be mounted/removed without tools, as it was designed.
I might be able to repair this loader if i knew what was missing, this is why i need pictures of someone else's 7308 loader.
Can anyone help me?:confused3:
If so, please email pictures to: tjohnson@nebat.com
Thanks,
TJ
   / loader trouble #3
The bolt on attaching parts were made available from New Holland for the early 7308 loaders. The original latches were not strong enough and the loader would become loose on the mountings. I would use the bolts if I were you even though it is somewhat inconvienient.
   / loader trouble #4
Sent you some pics that I had on hand. Hope that helps a little. Will take some better ones tomorrow. You can look at the parts drawings that are on New Holland's website too.
Good Luck,
Gerry
   / loader trouble
Thanks a bunch, guys! Sure appreciate the leads for pix and info. I will check into the options you all mentioned and see what I can come up with. This is my first compact as well as my first F/NH so I didnt know about the dedicated site for parts.....many thanks!:thumbsup:
TJ
INGERSOLL RAND INDUSTRIAL AIR COMPRESSOR (A51248)
INGERSOLL RAND...
2017 Freightliner M2 106 T/A 4,000 Gallon Water Truck (A51692)
2017 Freightliner...
2008 FORD RANGER SINGLE CAB TRUCK (A51406)
2008 FORD RANGER...
2016 Peterbilt 567 Tri-Axle Dump Truck (A51692)
2016 Peterbilt 567...
UNUSED MOWER KING 72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
2012 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2012 DRAGON...
