Loader running slow after grapple work
/ Loader running slow after grapple work #1
8NAcres
Garland, Texas
Kioti DK45S w/ KL451 Loader 1954 Ford NAA 1948 Ford 8N 1939 Ford 9N
I finally got around to installing my new grapple and rear remote hydraulic lines today. I had a fairly large tree that died and fell on the fence line so I thought that would be a good test of the new grapple. The tree was heavy - but I would say it was well within my lifting capacity. I was angled slightly down in a drainage ditch by the road and lifted the tree and tried to back out. I forgot the transmission was in a higher gear so it stalled on me. I put it in low gear and when I restarted there was a horrible squeal like when a loose car belt is slipping on acceleration from a stop. It lasted about 5 seconds then went away. Everything worked fine but I noticed when I got to the burn pile the lift was operating much slower. I figured it was because of the heavy tree, but even much lighter loads after that was slow as well.
It is a DK45 with a K451 loader.
Any thoughts?
/ Loader running slow after grapple work #2
Check the quick connects on the loader. Cycle the loader fully a couple of times. Disconnect the grapple lines and try the loader again. I assume you have the gear version?
To be honest with you - I am not sure what version I have (very new to the tractor). I have done quite a bit of online searching on this issue since I originally posted, and it seems this issue is pretty common on about ALL tractor makes and models - and the solutions are all a varied as the brands. Seems a common theme though is the hydraulic oil getting hot. I will try your suggestions and see if it works.
EDIT: It is a gear type. From the brochure:
Pump - Gear(Tandem)
Pump capacity(Max. flow rate) gpm(ℓ/min) - 1st : 9.88 (37.4) 2nd : 4.33 (16.4)
/ Loader running slow after grapple work #4
Did you add more fluid after you installed the grapple and lines. You may be low on fluid.
I did not add more fluid. My research showed I should not need to but that is a good thing to check. The hydraulics were working fine the first couple of hours I used the grapple after hooking the new lines up - it only started going slow after trying to pick up the large tree and the squealing. I was angled down into a drainage ditch while trying to get to it so I wonder if I got air in the lines or something(?)
/ Loader running slow after grapple work #6
You got air in the system as soon as you plugged those 2 dry lines and the cylinder in. When I put mine on and ran it for a little while it was 2 gallons low. That also included a few leaks I had when I started it up. My hydraulics did the same, ran slow and weak but not squealing.
/ Loader running slow after grapple work #7
Pump - Gear(Tandem)
I didn't mean the hydraulic system, I know that's gear. I meant the transmission of the tractor, is it HST or shuttle shift. If HST, as it's a common tank, I was thinking you could have messed something up when you stalled the tractor. It looks like Walkin Horse has the answer though.
It is a shuttle gear transmission.
/ Loader running slow after grapple work #9
Test your pump for volume and see if it is pumping the 9.8 GPM.
Remove a cyl retract hose and place in a 5 gal bucket and see if the pump is doing it 's job.
You should pump about 1 gal in 10 sec.
Install a hyd pressure gauge in a tee in the IN port of the FEL valve and see if the relief valve is at specs.
GPM's determine speed of operation, and pressure determines force.
/ Loader running slow after grapple work #10
Low fluid is the first thing to check.
The way I read your post is that you are running your grapple using the rear remotes. If so, and the rear remote lever is left on and not centered it may cause the loader to operate slowly. I run my hyd. thumb for my forks off the rear remotes. If I don't center the remote back to the center detent position after grabbing something pressure is always being applied to the thumb and makes my loader operate slowly.
2019 Chevrolet Tahoe SUV (A61574)
2019 Chevrolet...
UNUSED AGT MX-MRW14 STAND-ON SKID STEER (A64280)
UNUSED AGT...
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2016 Volvo VNL T/A...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
2016 CATERPILLAR 926M WHEEL LOADER (A65053)
2016 CATERPILLAR...
KITCHEN AID REFRIGERATOR W/DRAWER FREEZERS (A64281)
KITCHEN AID...
