loader rams
/ loader rams #1
blake037374
Baton Rouge, LA
CT440
have any of yall had to replace the o rings for a leaky hydraulic loader ram? I have one that seems to have small leak. just wondering if they have kit for it because I didn't see it in t he online parts diagram.
/ loader rams
Here are some pic
/ loader rams
Sorry different post been having problems with app since iOS 8
/ loader rams
Ssdoxie. I don't see that. I put in that part number under search and it didn't find it. Here is what I see.
/ loader rams #7
I didn't pay close enough attention to the model, that part number is for a 7TL on CT2xx models with Rhino loader. To find it in online catalog: Scroll down through the model selection to find "Loader", click on that then it will bring up a little box on the left column for "compact tractor", from there go down until you find bucket and lift cylinder for (in your case) 9TL with the correct 1st 4 digit serial number.
The picture you posted is for a 9TL Rhino built loader serial number starts with AE35. Lift cylinder kit - 6693747 and tilt kit - 7003599.
/ loader rams
I def wouldn't have thought to keep looking for that. I figured it would all be under the model. Thanks for help.
/ loader rams
How do you pull that retaining pin out? Just pliers? This is my first one. I ordered service manual but it hasn't got here yet
/ loader rams #13
Blake, I have yet to take one of these apart. Read about it in the book but reading and doing are sometimes 2 different things. I suggest you ask this question in the Hydraulics forum and post the picture of the cylinder you posted earlier. If memory serves, manual saysing something like grap hold of wire clip and while pulling rotate the cylinder head until wire is removed, then cylinder head should pull straight out.
Sent PM to you also.
/ loader rams
just FYI im gonna try and get someone to video it so I can put on youtube. and on here.
/ loader rams
well got it apart and replaced seals....works like champ now. not leaking one bit. retaining clip was a SOB
/ loader rams #17
Will you put your video here, or on YouTube?
Is the chrome nice on your cylinder rod? Per the pic., it was not so clear...
I just did a repacking on a similar cylinder. I used vise grips to get the wire out, and reused it no problem. Just went slow pushing in.
/ loader rams
sorry for late response having trouble replying from phone. my kid deleted my video from phone but my cylinder rod was that color all the way and both rods. only part that was shiny was the threads on end. I ended up using vise grips as well. my was rusted and not sure i could re-use so put grease around new one and it went in just fine.
Kubota SVL 75-3 (A64126)
Kubota SVL 75-3...
L Shaped Transfer Tank (A64119)
L Shaped Transfer...
UNUSED WOLVERINE RIPPER (A64281)
UNUSED WOLVERINE...
STAINLESS STEEL CABINET (A64281)
STAINLESS STEEL...
2021 Caterpillar 259D3 Compact Track Loader Skid Steer (A61572)
2021 Caterpillar...
2014 Ford F-550 Altec AT40M 40ft Material Handling Bucket Truck (A61568)
2014 Ford F-550...
