Loader question
   / Loader question #1
robert23239
Does anyone know if the deere 52 loader will fit the 955 tractor ??
Also how much do you have to worry about blue smoke coming out of the exhaust during throttle up??
Robert
   / Loader question #2
I don't know about the loader. The blue smoke, depends on how much. Just check the oil level until you get a idea on how much it uses. I check mine every other time I use the tractor and if I can't remember I check it. Your tractor may just have some blow by until it reaches operating temp.
   / Loader question #3
I believe the 955 matches up with the 70A loader.
Blue smoke is generally not a positive thing you want to see with any engine (unless it's a 2-stroke). You might have ring wear or worn valve guides. If you note increased oil consumption - do a compression check.
That said; engines will run for many hours with either or both conditions - but not peak performance.
AKfish
2005 Mitsubishi Lancer ES Sedan (A54815)
2005 Mitsubishi...
Hose Reel (A55758)
Hose Reel (A55758)
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2019 GENIE...
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
New Holland 325 Manure Spreader (A55218)
New Holland 325...
(2) LITHONIA LIGHTING LUMINAIRE FITTING LIGHTS (A54756)
(2) LITHONIA...
