Loader Problem
   / Loader Problem #11
<font color="blue"> Someone correct me if I am wrong. </font>
Ok, I will. Your wrong. When the cylinder drops faster than the fluid can refill the void, the air is pulled out of the fluid under a vaccum. That is where the problem is. It has nothing to do with how much fluid is in the tank or on the dipstick.
   / Loader Problem
Thanks for your reply, Jerry. You have forced me to “hit the books” in my old age.
I did some text book research on fluid dynamics and rediscovered the phenomenon of a “gaseous condition within a liquid stream caused when pressure is reduced to vapor pressure”. I also realized that all of the fluid movement and agitation present in the tractor gearbox and differential case causes air bubbles to be entrained in the hydraulic oil. I was neglecting to take this into account in my “theory of operation” when the piston end of the cylinder is under vacuum when dumping a heavy load, thereby causing cavitation.
I also now understand what a regenerative circuit is in this application, why it is helpful and how it works. What I need to do now is find out if the DK65 integral spool valve has one and if so, whether mine is working correctly or not.
Thanks again.
   / Loader Problem #13
If it does have a regenerative circuit, you should be able to feel a detent as you move it to the right. As it moves past the detent, it will be in regenerative if the valve has such a option.
   / Loader Problem #14
Jerry,
Will it actually have to have a detent position to have this function? Doesn't some of the smaller Kioti loaders have this feature now in the dump position? I think mine does but there is no detent. I was assuming it was just something in the way the spool is machined. I have to go find the article not too long ago about this on the Kioti loaders.
Steve
Case 1020 25ft Draper Head (A56436)
Case 1020 25ft...
2013 John Deere 650K Crawler Tractor Dozer (A56857)
2013 John Deere...
1990 MACK RD688S (A58214)
1990 MACK RD688S...
Sakai SV540T Padfoot Compact Roller (A57453)
Sakai SV540T...
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
2020 KUBOTA RTV...
