Loader Loader problem solved
   / Loader problem solved #1
B2930 By the Water
Montreal, Canada
kubota 2920
Hello everyone,
I thought I would share with you'll my adventure with the erratic behavior of my loader.
Originally I thought that the erratic operation was due to low hydraulic fluid, I try to look into the manual and found very little info on how to check nor put in the hydraulic fluid, thus I added some in the orange cap, not really knowing what I was doing. Then panic set in and I found Tractorbynet.
Thanks to everyone that answered my quest, I did not start the tractor and called the dealer and insisted to talk with the mechanic, found the location of the gauge and drained the excess fluid I had put in.
After eliminating the hydraulic fluid mishaps (adding too much) I was back with the erratic operation on my front loader. I just got my tractor and the first few time I used the loader it went fine. After removing the loader a few times to mow the lawn, I started having erratic operation lifting the loader.
I only realized last weekend that after raising the mower and locking it at the top, sometimes I would leave the leaver activating the lawn mower up and down, at the highest position, this seems to create the problem with the loader operating erratically. I remove the loader and put it back on a few times, making sure the leaver was at the lowest position and it works fine now.
I don't have a clue why the mower leaver would prevent the loader to function properly but, it did, if anyone knows why it would do that, I would appreciate the explanation.
Hopefully this can help someone,
Al
I have a 2920, when I originally registered I made a mistake.
Thanks for the link,
Al
   / Loader problem solved #4
Yeah, this place has saved me from doing something really stupid once or twice.
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
2017 Ram 1500 Pickup Truck, V6, 4X4, Automatic Transmission, 212,570 Miles (A56438)
2017 Ram 1500...
John Deere 690B Excavator with Auxiliary Hydraulics (A57024)
John Deere 690B...
2017 Ford F550 Bucket Truck (A60460)
2017 Ford F550...
2012 DOOSAN G25KW GENERATOR (A58214)
2012 DOOSAN G25KW...
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
