Loader Loader performance on GC2610
/ Loader performance on GC2610 #1
ScottAW
I'm trying to determine if I have a hydraulic performance issue. It seems to me that the loader had the power to raise the front axle off the ground when I first got it. With the bucket rolled forward so the cutting edge is pointing down, I then try to lower the arms and raise the front axle. Does anyone with a GC know if this is normal to not be able to do this? I know if my backhoe is on that helps significantly, but I thought the loader could do this without the weight of the backhoe too.
/ Loader performance on GC2610 #2
It depends at what engine speed you was trying to do it at. At idle it will not do it . I was doing it today with out the BH on my 2310 with 675 hr.
Doug
/ Loader performance on GC2610 #3
Doug
+1:thumbsup:
/ Loader performance on GC2610 #4
My 2400 has raised the front wheels off the ground, at an idle, for 2 years now. I can do it without using the curl function.
/ Loader performance on GC2610 #5
At idle I can lift my tractor up with the FEL, I can also lift a 500 lb rock with the BH when idling. There is a guy who has a youtube video lifting a monster of a rock from his foundation with the BH on idle(GC2310)
Must have been a fluke, air, or cold fluid... A few days after posting this I was running the tractor at PTO rpm for a while when back dragging and grading. Went to life the front axle with the loader after to slide the mower under, no prob! Strange why I had an issue....
