Loader Loader movement
   / Loader movement #1
rostark
JD 4700
I have a 4700 Compact Tractor which gets alot of loader work. The loader has begun to get loose on the support bar,that 4x4 steel bar that runs under the tractor. Anyone else experience this and if so, were you able to correct it?
   / Loader movement #2
The towers that support the lift arms should have a clamping mechanism that ties them to the subfram. That information should be in the installation manual and the torque values. The subfram may also be lose, again refer to the installation manual.
   / Loader movement #3
I don't have any personal experience, but if you do a search there are several threads about these kinds of problems. ( I used "Loader shims" as my search criteria in the J.D. owning/operating forum.)
UNUSED AGT TSOCPF48 MAST W/ 48" FORKS (A51248)
UNUSED AGT...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
20711 (A51694)
20711 (A51694)
20 ft Angle Boom (A53117)
20 ft Angle Boom...
