Loader Joystick
/ Loader Joystick #1
ktoom
Albany, New York
1966 JD300. 2005 GT245, 2014 Mahindra 4035HST
Has anyone ever converted their cable style joystick to a all hydraulic setup? Aside from the cost, it seems like it would be farely easy.
I cant stand the slop in my non adjustable cable actuated joystick lever on my mahindra 4035 loader.
Thanks
/ Loader Joystick #2
Never done it. But do you have room to route all the necessary hydraulic hoses to the location you want the valve. Should be looking at 7 hoses for a typical valve. So probably ~$200 in hoses, $300 in a hydraulic valve, Maybe another $100 for miscellaneous fittings, tax, shipping charges, etc.
If you have room, and the slop is worth $600 to correct, go for it.
/ Loader Joystick #3
By all hydraulic do you mean hydraulic pilot of your current valve? If yes then no you cannot convert existing valve without adding hydraulic pilot operators (if even an option) and getting a hydraulic joystick and the necessary valves to supply a constant pilot pressure source.
I would probably first investigate a way to make the cable version adjustable. Possibly just require new cables with adjustable ends.
/ Loader Joystick
There is plenty of room to attach a valve with hoses to the current pedistle.
The current loader valve is underneath the right side of the tractor.
Here was my thought:
1. I take the current loadervalve out.
2. Extend the hose's, that go to the current valve, to the new valve.
I would be adding 3 feet of hose, in order to relocate the valve.
Sounds like its not that easy?
/ Loader Joystick #5
Most of that stuff is fairly easy; I'd consider adding an extra spool for a grapple, I'm doing that to mine (waiting on more fittings!) but mine started with a direct acting valve, so my hoses already reach.
/ Loader Joystick #6
If you just relocating the existing valve then yes all would need to do is reconnect all the hoses and add the lever operators
/ Loader Joystick
In order to re-use the existing valve, i would need to find a joystick setup that would mount to the spools. This is the only reason for buying a new valve.
I will have to do some research to find out who Mahindra uses for their hydraulic parts.
/ Loader Joystick #8
It depends on who made the particular tractor. TYM? Perhaps Besko (good luck trying to find them besides a Mahindra dealer!). The smaller tractors may be Mitsubishi built. In any case, I'd be surprised if you can actually find a joystick setup to mount on your valve. It would be easier to simply get a valve assembly from Surplus Center (you can customize and get exactly what you want, maybe a joystick for the loader, a grapple spool, and a motor spool.)
/ Loader Joystick
The 4035 is built by Mahindra them selves. The tym built tractors are from a different series as well as the mitsu. tractors.
My tractor is rated at 11gpm. Does that mean I need a joystick that will do 11gpm or more?
/ Loader Joystick #10
Yes, if it is in the open circuit and you use power beyond. Note that you'd only need that for full flow at full throttle, but you don't want to choke the system in any case. I'm going with a valve that is technically too large, because it was a joystick assembly with grapple valve at a reduced price. You can "build a stack" on the Surplus Center site, getting, say, one regular D/A spool, one with float, another if you want to add a third function, add a joystick, etc.
/ Loader Joystick
I pulled out the valve assembly and its made by Cross. I wrote down all the numbers I could find on the unit and nothing came up on Cross's website. Any ideas where else I might be able to search for hydraulic parts? Ive already used surplus center too.
3 Bag Air Jack (A66408)
3 Bag Air Jack...
Saddle Tanks (A65640)
Tool Bar (A64127)
Tool Bar (A64127)
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
2021 Peterbilt 389 Sleeper Truck (A62613)
2021 Peterbilt 389...
2014 DRAGON  130BBL VACUUM TRAILER (A65643)
2014 DRAGON...
