loader issues
   / loader issues #11
What size bolt? Did you have enlarge frame holes to resize tapped holes? Flat mating surfaces? Using heavy flat washer and lock washer? Rounding and chamfering all edges? Like others have asked, pictures can be very helpful diagnosing issues.
Many engineering techniques to minimize stress risers to prevent cracking materials. There are rare bad batches of materials but not enough information given.
Yepper. I'm still missing too much info. Don't understand the geometry & need some photos. In fact, not even sure what is breaking where? What got rewelded? Is there a casting involved? And why would this be a Mahindra part rather than a standard bolted joint? Too many questions.
Half a dozen TBNers could design a fix for him - especially if he can fab metal.
   / loader issues #12
No question - something here is wrong. I've had tractor w/loader for 40+ years and never a problem such as this. Never heard of this before either.
A thought - is the loader frame designed to operate on the OP's tractor. I ask this because if it is not - it could be that the hydraulics are the major cause of bolt breakage.
If grade 8 bolts are being sheared - something is surely out of wack.
   / loader issues #13
Don’t have the exact same machine, but close cousin. Not sure if this helps, but Mahindra doesn’t make their own loaders and backhoes. They’re added at Mahindra US assembly plants. They use a few different suppliers, mine are made by KMW in Kansas. 4 of the six engine mounting bolts get replaced with 12mm x 1.25 x 40 Grade 10.9 bolts which attach the subframe to the tractor. Not sure who makes your loader, but would think the mounting bolts might be the same.
   / loader issues #14
I regularly check the prevailing torque on the loader frame to chassis fasteners according to the call out in my owners manual. Part of continuing maintenance.
   / loader issues #15
I think in order for that to happen the hydraulics of the loader must be involved somehow, perhaps an alignment/binding issue forcing the hydraulics to deflect something that normally does not deflect.
Will this mounting plate sit flush to the tractor without the bolts installed, or does tightening the bolts ‘pull down’ the plate and every time it breaks a gap is created between the previously clamped parts?
   / loader issues #16
I can remember the chinese made some
so called #8 bolts but they were really like
#2 and created a lot of problems
willy
2014 Mazda CX-9 Sport SUV (A56859)
2014 Mazda CX-9...
2024 DIGMASTER MINI EXCAVATOR (A58216)
2024 DIGMASTER...
Cushman Electric Cart (A55853)
Cushman Electric...
2025 Wolverine MAD-12-12D Auger Mini Skid Steer Attachment (A56857)
2025 Wolverine...
MODEL 14C SCRAPER (A58216)
MODEL 14C SCRAPER...
Truck Metal Cargo Storage Box (A55788)
Truck Metal Cargo...
