loader issues
   / loader issues #1
matk
mahindra max 26xl
just gotta ask if anyone else is having or had this issue i have a 2016 mahindra max 26xl 125 hrs on it the front end loader mount that mounts to the frame 1/2 inch steel keeps breaking all bolts that hold to the frame all have broken in the frame and no was not overloading it was hauling bags of mulch only the loader control valve side call to get a new one there outta stock so makes me think this is a major problem
   / loader issues #2
I don't have your machine, but candidly it sounds as if they used a coarse thread grade 2 bolt to attach it to the tractor's engine cradle side plates
instead of a Grade 8 fine thread bolt washers and fine thread grade 8 nut securing it with red loctite and a torque wrench using the recommended
lubricated torque value to torque the nuts. IN short, your dealer cheaped out on installing it right if you bought it with a loader.
   / loader issues
thought that as well so i taped the holes used grade 8 and its still snaping the bolts and the mounting plate its like im hitting a wall at a 100 miles an hour and of course thats not true cant go that fast
   / loader issues #4
Wow that's odd. Do you have any pictures you could post, either of the snapped bolts, or even the current mounts?
Most of the loader bolt issues I have read about are a direct result of improperly torqued bolts, or loosening bolts over time. Not saying that's the case here...
   / loader issues #5
What size are the bolts?
   / loader issues #6
Are the bolts pulling the bracket tight against the frame ? do the treaded holes seem lose at all? if they are lose is the holes deep enough to use a slightly longer bolt ?
   / loader issues #7
MATK, we are missing something here. I thought in 20 years of talking about mechanical stuff the TBN guys would have covered everything - but I can't remember hearing this problem with any make of loader.
You mentioned they were "out of stock", so are these special dealer bolts for this loader? Why would you have to tap the holes? Drill and Tap to what size? Apparently these aren't just your standard thru-bolts with nuts.
I'm thinking we need some more info. Which bolts? Where? How did they break? Any ID markings on the bolt head?
Photos would help if you can figure out how to post them. Photos of the broken bolts especially.
Good luck,
rScotty
   / loader issues #8
Yeah, I agree. Something ain't right here. In my lifetime, the only time I've seen broken bolts on a loader was from misuse.
Would love to see pictures.
   / loader issues
okay bolts sheared off in the frame so i had to weld nuts on to get them out so i retaped them to american threads used grade 8 fine thread still sheared them off only on the right side call mahindra there out of stock on the right side only mounting plate this is where im having issues is bolt shear off and when that happens it breaks the mount 1/2 in steel i have welded it back together and it breaks in another spot it breaks it to 2 pieces like i said before its like im doing 100 and hitting a wall so is this there flaw on that side is there another loader mount that would work or am i just SOL
   / loader issues #10
What size bolt? Did you have enlarge frame holes to resize tapped holes? Flat mating surfaces? Using heavy flat washer and lock washer? Rounding and chamfering all edges? Like others have asked, pictures can be very helpful diagnosing issues.
Many engineering techniques to minimize stress risers to prevent cracking materials. There are rare bad batches of materials but not enough information given.
2004 INTERNATIONAL 4300 BOX TRUCK (A51222)
2004 INTERNATIONAL...
2015 Dodge Charger Sedan (A50324)
2015 Dodge Charger...
7021 (A50322)
7021 (A50322)
2021 CATERPILLAR 303E CR EXCAVATOR (A51242)
2021 CATERPILLAR...
1996 Lincoln Town Car Sedan (A50324)
1996 Lincoln Town...
2008 GMC C7500 Altec LRV55 55ft Forestry Bucket Truck (A50323)
2008 GMC C7500...
