Loader Installation Lessons
/ Loader Installation Lessons #1
ritcheyvs
Kittrell, NC
Kioti DK45S
I put my loader back on today (for the first time ever) after fixing the IP and performing 500 hr maintenance. Despite unlevel/curved ground, I found it easy to drive the tractor back into position, just go slow. It was about 40 degrees hotter than when I removed the loader so I had to use a hammer and rag to depressurize the loader hoses; I expected that. My main problem was that I had raised the bearing box too high when I removed the loader so I didn't have enough slack in the hoses to reconnect the lowest hydraulic quick connector. This may not be an issue on flat ground, I don't know. Finally, I disconnected a boom hose to get enough clearance to connect that bottom curl hose and then curled down to lower the bearing box enough to reconnect all hydraulic hoses. I should have anticipated this because I had a hard time disconnecting that bottom hose when I removed the loader. After that it was a simple matter to align the big holes for the latch pins by playing with the joy stick One pin slid in easy but the other required light hammering. I had dreaded this but it was not a bad.
/ Loader Installation Lessons #2
The first time probably took me 20 minutes to get back on. After that I’m probably closer to 5 minutes. It’s definitely worth while doing for any amount of mowing. It rides better, the visibility is better, and the power is better since you’re moving less weight.
Well, except for the problem with the quick couplings, I probably needed 5-10 minutes. When I make new hoses for a deverter valve I'll add some slack to avoid this problem.
My DK45 is heavy but has plenty of power, so mowing with or without the loader makes little difference.
/ Loader Installation Lessons #4
FWIW:
I had a heck of a time remounting my loader. I could not get holes to line up.
After much frustration and many suggestions from the forum (thank you) I found the problem to be sand in the bottom of the cradles where the loader arms sit.
I imagine it fell in there when I removed loader.
Anybody having problems always clean out the area where your loader arms sit.
Lesson learned.
drjay: I read your saga about the time I removed my loader. With the loader off, I pressure-washed the engine to remove most of the crud before opening up the engine for IP repair. While I was doing that, I blasted out the loader cradles so I didn't repeat your drama. Thanks for the lesson.
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
Lonestar Panel 24ft. Free Standing Panel with 7ft. Gate (A65640)
Lonestar Panel...
2013 Ford F-150 Pickup Truck (A64194)
2013 Ford F-150...
2012 International Prostar (A63118)
2012 International...
SKID STEER VIBRATORY ROLLER (A62613)
SKID STEER...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
