ritcheyvs
Veteran Member
I put my loader back on today (for the first time ever) after fixing the IP and performing 500 hr maintenance. Despite unlevel/curved ground, I found it easy to drive the tractor back into position, just go slow. It was about 40 degrees hotter than when I removed the loader so I had to use a hammer and rag to depressurize the loader hoses; I expected that. My main problem was that I had raised the bearing box too high when I removed the loader so I didn't have enough slack in the hoses to reconnect the lowest hydraulic quick connector. This may not be an issue on flat ground, I don't know. Finally, I disconnected a boom hose to get enough clearance to connect that bottom curl hose and then curled down to lower the bearing box enough to reconnect all hydraulic hoses. I should have anticipated this because I had a hard time disconnecting that bottom hose when I removed the loader. After that it was a simple matter to align the big holes for the latch pins by playing with the joy stick One pin slid in easy but the other required light hammering. I had dreaded this but it was not a bad.
