Loader hook up question
   / Loader hook up question #1
Kubota Greg
I am adding a FEL to my B7100 HST-D. I want to tap the hydraulic block to feed the control valve. Can anyone help me with the following questions...
1. What is the thread size of the plug in the hydraulic block?
2. Can I simply feed the spool valve from the hydraulic block and then simply have the return line feed back to the transmission as a low pressure line?
3. The loader, from a Bolens tractor, it's a Johnson TC-10. I am almost 100% certain that Johnson made this loader for Kubota back in the day who called it a B219. It used it's own pump and the fluid reservoir was in the right side up right. (I will be using the tractors hydraulics) Is it most likely that the spool valve was not a power beyond valve? Meaning if I use this valve, I must use it with the exiting line as low pressure? I'm still learning hydraulics, I only bough my 1st tractor 4 weeks ago.
Any help you guys can offer will be greatly appreciated.
2006 Isuzu NPR 16FT Box Truck (A50323)
2006 Isuzu NPR...
1997 John Deere 8100 MFWD Tractor (A52128)
1997 John Deere...
2016 Ford Fusion Hybrid Sedan (A50324)
2016 Ford Fusion...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2016 Ford Transit 250 Cargo Van (A50323)
2016 Ford Transit...
John Deere 693 Corn Head (A50514)
John Deere 693...
