Loader Loader Functions
   / Loader Functions #1
Stuart M
Regina,sk
Bobcat S185, T190
I recently bought a Massey 180 tractor. It came with an aftermarket loader. The loader seems to function fine but will not lift anything if it has any material in the bucket. I am assuming the hydraulic pump is weak? Any suggestions on what to check first?
   / Loader Functions #2
I would check to see if you can find a relief valve anywhere. If there is debris in the hydraulic fluid it could be sticking partially open and cause a lack of power when lifting.
   / Loader Functions #3
The pressure, then you don't have to assume, you will know. :thumbsup:
   / Loader Functions #4
Ditto. Get a gauge and check pressure
KMC 5610 (A53084)
KMC 5610 (A53084)
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A53473)
PENDING SELLER...
2012 Bobcat T870 (A50123)
2012 Bobcat T870...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
