Forks Loader forks on 3pt iMatch
   / Loader forks on 3pt iMatch
Thanks. These forks are the floating or sliding kind. They slide back and forth on the heavy rod at the upper part of the frame. The forks came with a locking collar that has a locking set screw to hold each fork from sliding on the rod. I didn't like that arrangement so left the collars off when I assembled the forks.
Instead of the collars, I added large washers on either side of each fork, and then made spacers out of pvc pipe, cutting about an inch out of the side wall of each one. These spacers can be seen in the above picture (3rd one), and snap in place between the washers to make changing the spacing of the forks just a matter of removing a spacer, then snapping it back on the rod after sliding the fork over.
The various tasks I use the forks for, and the different settings for different pallets, make changing the fork position a fairly frequent event. May be digging out rocks one moment, picking up brush piles, carrying logs, moving pallets, or digging flat limestone rock - whatever that means different positions for the forks. I don't think I could survive with fixed-position forks.
   / Loader forks on 3pt iMatch #12
Nice job! Not much a little ingenuity can't conquer. Sparked idea # 14??? You guys... /forums/images/graemlins/smirk.gif
Now I just need to develope a few more skills. I ordered the welding book this morning. It's all your collective fault you see. If my wife had any sense she'd take this computer away from me. /forums/images/graemlins/shocked.gif /forums/images/graemlins/grin.gif
2005 Ford F-150 Pickup Truck (A54814)
2005 Ford F-150...
Electric Forklift Pallet (A50322)
Electric Forklift...
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A53421)
2014 JLG G12-55A...
2002 Western Star 4900 T/A Galbreath Rolloff Truck (A55852)
2002 Western Star...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
2015 Nissan Altima Sedan (A55853)
2015 Nissan Altima...
