Loader for a l3430 hstc
   / Loader for a l3430 hstc #1
jca57jd
Charlotte NC
Kubota L3430 HSTC 2006 Bobcat T190 (60" CID) Cat 303.5 Bobcat e55 (50" blue diamond mower)
Hey guys. I'm wanting to buy me a loader for my 2003 kubota l3430 hstc. From research it seems like I need the la723 loader. I would buy a woods if I can get a package that works with my cab. Where should I start on looking for a compatible loader for my tractor with the cab given that it's a 14 year old unit? Thanks!
   / Loader for a l3430 hstc #2
That's the right model. I have a QA attachment for the 723 if you need one, once you find the loader.
   / Loader for a l3430 hstc #3
The 723 or a 524? should work.I know they offered two loaders.After market probably will be cheaper.The 723 has more lifting capacity.
It seems to be pretty hard for me to find a la723 right now. Is it going to be a challenge for me to find one?
   / Loader for a l3430 hstc #5
Probably, usually sold with the tractor.
   / Loader for a l3430 hstc #6
I would start at the Local Kubota dealer;they may one or have a source.Several models/years used that loader.Koyker or Woods may be worth a call.
   / Loader for a l3430 hstc #7
The LA-723, LA-513 were the original loaders for the small frame Grand Lxx30 series tractors the LA-724, LA-514 were for the Grand Lxx40 tractors the LA524/ LA764 is for the smaller L series L3200 L3800 L4600. If you had a subframe mounted backhoe you usually need the larger 700 series loader to tie into the subframe for the backhoe.
No idea if the Grand L 40 series loaders will work on the Grand L 30 series or not as the hydraulic valve location changed on the non cab tractors. There were also conflicts with the 700 series loaders and the mid mount mowers used on the Grand Ls also not sure about the front quick hitch mount though.
David
   / Loader for a l3430 hstc #8
The LA723 and LA724 are very different.
New Holland T2420 (A53317)
New Holland T2420...
2017 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A60429)
2017 CATERPILLAR...
2010 Honda CR-V SUV (A59231)
2010 Honda CR-V...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
2007 CHEVROLET 3500 DUALLY 4X4 DIESEL TRUCK (A59575)
2007 CHEVROLET...
PNEUMATIC GREASE UNIT (A58214)
PNEUMATIC GREASE...
